Cliptin
Location
Chattanooga
Cliptin's Achievements
Advanced Member (3/11)
11
EJ20g into GL10 Wagon almost done ~EDIT DONE~
Cliptin replied to suberdave's topic in Subaru Retrofitting
I could not find where you answered the question about using a JDM transmission in the GL. Assuming you did, did you have to do anything special? -
2)The 2.2 doesn't have the potential HG problems of the 2.5. 1)I already have one.
Pardon my ignorance but how do I tell if the 2.2 I'm looking at is single or dual port?
Is the computer smart enough the adjust? Will the transmission mount up easily? Anybody done it?
move over EJ22 swap, I need a quasiturbine!
Cliptin replied to baccaruda's topic in Subaru Retrofitting
"Not easy and not frequently. However, the inventors occasionally give local Montreal conference, demonstration and training. See: http://quasiturbine.promci.qc.ca/QTDemonstration00.htm " -
Oops.This should probably be moved to the retrofit area. Sorry Mod.
I just bought a 2.2 engine to drop into my EA82 with AT. Should I expect reliability problems or premature failure? What can I do to reduce help?
Anybody know how much one of these kits costs? Two calipers.
The end of that board looks like a 1x6 or 1x8.
I'm going to be working on a friend's car this coming weekend. Is there anything special about the O2 sensor or where to get it from? Her regular mechanic is having trouble sourcing it and they send him the wrong one. Is there any remedy for regularly warping rotors? She drives up and down the mountain every day. Better quality/slotted/...?
I have two injectors that glisten and smell like fuel after a drive. They seem to be leaking from a small hole right below the rubber connector hose. Are these guys repairable or what is the board consensus on replacement?
