About rllywgn
- Birthday 05/21/1980
Contact Methods
Website URL
http://
Yahoo
rallywagon87
Location
Vegas Baby
Interests
subaru's and sleeping
Occupation
HVAC Tech
Ezboard Name
posioaui
Vehicles
88 Gl-10 turbo sedan 5spd
Recent Profile Visitors
rllywgn's Achievements
Subaru Fanatic! (6/11)
11
EJ22 swap starts & runs for 20 sec, then dies.
rllywgn replied to robcor2's topic in Subaru Retrofitting
my supra had a the same thing happening a while back.. would run for up to 20 seconds then die. it took a fuel pressure tester to show me the problem. the pump would build pressure when starting but would drop immediately after engine was running. my issue ended up being a leak, but in my search for a solution i checked the fuel pressure regulator, fuel rail damper, filter, and pump. it may be related to the pump not being triggered by the ecu, but how would the ecu know? can it sense electrical load? or perhaps its part of an electrical loop? would make sense in the above mentioned accident scenario when you would want that to shut down immediately with the engine. so yeah, check the fuel pressure, as i recall it should be between 40-45psi, someone correct me if im off -
the compressor is designed to cycle based on refrigerant pressure, as it fluctuates with engine rpm. however the blower shouldnt turn off. i would check the relays for both the blower and hvac. on some wrx's i've worked on its been just a poor connection where the relay plugs in.
oil pump is a definate yes, dont really want to mess with the water pump. engine has about 40k on it and cooling has been extrodinary. Las vegas heat and a/c full blast dont move my temps past 195f. i will however inspect it. just dont want to mess with a good thing. car has a 2 row radiator, extra electric cooling fan and a notched custom front bumper. I will take it in to consideration though..
pulled the distycap tonight before towing it home and turned the motor over.. rotor didnt spin, appears to be a broken timing belt. id rather replace that then try to find a short. did replace the coil and amplifier in hopes of getting it home without a tow, but as i see it now i have a upgraded coil. so, oh well.. atleast i know whats up, thank you all for your help
timing belt failure will stop the coil from firing? makes sense but my brain is running at about 12%, between work and the car ive used up all of my alotted brain capacity for the day.
So it's been a while since i last posted, just been lurking around and reading through. but now i must, my gl-10 turbo has me stumped. Yesterday after driving about 25 miles the car died and wont restart, checked the obvious things, fuses, fusible links, fuel and what not. what im missing is spark! all fuses are good, fusible links are good and have tight connections. with the key in the on position i have 12 volts at the positive terminal on the coil and 2.3 volts on the negative terminal. i tested the coil/dist plug wire ohm, and turning over no spark output to dist. I attempted to locate the ignition relay above the ecu, not sure i can even see it, moved the ecu to the side and all i see is wire harness and steering column. I've searched but some of the explanations i've read arent too clear or semi close to my current problem. any help is greatly appreciated. 1988 GL-10 turbo 5spd
jdm style grills for gen 3 cars
rllywgn replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
speaking of.. what happened to his car? havent seen his name in years it seems. sorry bout the threadjack! -
They came with the lights when i bought them. And as a side note the 500's are going to be getting nieghbors in the form of 7" hid floods in a 4 light rally pod:grin: -
like this grill? home depot grill as well -
'86 GL AC Compressor Question
rllywgn replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when theres no pressure in the system the high/low pressuer switch opens the circuit. depending on how he tested it he might be wrong. as others stated compressors don't fail all that often. usual failures are bad front shaft seal, failed/burnt clutch, and bad bypass (some cars). fill the system with nitrogen (an inert gas) and check for leaks. while the sytem is filling you'll hear the pressure switch click to closed. then check the compressor circuit. I'm an epa certified HVAC/R technician for both automotive and commercial/residential comfort cooling. I have serviced and repaired more cars than you can shake a stick at, and replaced compressors in only a handful of them. Dig a lil deeper before condeming the compressor. I'm in las vegas if you would like to schedule an appointment:grin: -
new wheels needed... EA82 wag what offset?
rllywgn replied to boxerbob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
im running 18x7.5 prodrive p1's with a +53 offset. 215/40/18 is as much tire as i can get under the car with rubbing in the rear on the torsion bar. with a +48 i could go a little wider on the tire. -
Soobspeed Intake and front strut bar
rllywgn replied to bluto5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nice setup.. piping looks excellent.. I would like to see the intakes available with the option of using a larger filter -
check the for sale section of this forum. Depending how norcal you are, i would check some of the pic-a-part's in medford. or any p-a-p for that matter.
