Everything posted by cal_look_zero
There's a reason that VWs, luxury cars, and especially Subarus get notoriety for being "unreliable" They're cars that are primarily owned by drivers; not mechanics. People don't tend to pay any attention to a car until an idiot light comes up, it smokes, or doesn't run. So when you have a car that has some quirks that can lead to failure, most people don't notice until that failure happens. Whereas most of us would pull over and shut the car off at first sign of a temperature rise, they'll drive until the car shuts off from melting parts. Just my $.02. I have remnants of two phase I 2.5s that were ran dry on oil, and I just bought a legacy that disintegrated a timing idler and collided valves and pistons.
There's a difference between "can't" and determined it to be unnecessary since the block was probably done within 500 miles of the engine going. Yes, all of the signs pointed to a bonehead rebuild and subsequent failure of the engine. Properly reassembling/resealing the oil pump was a procedure the PO should have followed a little closer. Anyways! All ready to get assembled when my parts start coming in the next week or so. These engines are surprisingly simple to build from scratch. Then again, the last time I split cases, I was 17 and rebuilding a VW 1600.
Definitely a capable machine. From driving mine in stock trim vs an L in stock trim I could tell that the suspension is stiffer, larger tires, and aesthetic differences; hood, 2 tone paint, bumper cover, roof racks, etc. However all GC/GM/GF cars use pretty much the same parts, and as such a lot of the newer (GD) parts also swap over. I have STI springs from a 2004 installed, and am in the process of building a "frankenmotor" from about 4 different engines; using the block from a 98 Legacy 2.5 Short story: Better starting platform than a Brighton or L IMO. Not quite an RS.
The machinist didn't want to screw with decking the block, so the HG is the only point I'll be shaving any depth. I almost have the block built, just waiting on enough time to commit to it. Not taking other builds as gospel, but the one I'm following closest had his block shaved 010 and ran 020 under HGs, so I doubt I'll have an issue.
GD sometimes forgets that not everyone is capable of doing their own major engine work/pulling their engine. I guess the heads could be pulled in car, but yick. If it's a POS old battlewagon, then just throw a new belt at it and drive it until it blows up. But if you plan on getting a lot more life out of it, pulls the heads and check the valves. Do a gasket and timing set from eBay while you're in there (they work fine if installed correctly) and have the peace of mind of knowing that the engine is less likely to blow up from sucking a valve.
I refer you to the carnage thread: http://www.ultimatesubaru.org/forum/showthread.php?t=131215 Basically I thought I was going to get 2 rebuildable engines, turns out I got 1 usable block out of the whole deal (aside from the parts I'm going to sell) However, some light at the end of that tunnel. I took my carnage rods and cranks to my usual machine shop to see if anything was salvagable. He took the parts in on trade towards a reground crank and set of rods. With all the bearings and piston rings, I spent $270 and will have a virtually new rotating assembly. So the build is back on the road. My (hopefully) good block is currently being hot tanked and honed, and I should be assembling my "new" shortblock this weekend.
Six star and Cometic are both good aftermarket brands, and not much more than OEM. I have seen a few more complaints about Cometic on the STi side of things, but a lot of that has to do with installation/application error. A stock application HG with standard head bolts will fail at high boost; no matter the brand.
I would try this guy first (they're not really bent like that, it's flexible). Drop it down the filler and see if it ends up where the tubing did. Get a good one at sears or something, I had a snapon one that would draw blood it had such a good grip. I'd strongly advise against driving around in hopes it will mash up. That's just asking for trouble.
Well this one is thrashed too. Between the 2 though, I should have a good engine after I find out if either crank can be saved and/or buy a good crank. Anyone have a good 2.5 crank? The second engine completely lost the #3 rod bearing and beat the hell out of the case. Probably salvageable, but the first case was nearly perfect. Going to definitely be a hodge podge like everything else, lol.
