Everything posted by cal_look_zero
Slow down tiger. Chances are if someone "gave" you a DOHC 25, you need to pull the oil pan and witness the phenomenon known as "The silver milkshake". 25Ds have a nasty habit of eating rod bearings. Not that it's the end of the world, but it's more trouble than it's worth. Ask me how I know... I'm in the process of sourcing an EJ257 (STi) engine to replace the 25D that I salvaged for my frankie. It's not that it's a bad engine by any means. But I have experienced my fuel cut at 6200rpm, and I doubt those internals will last me long at that rate... The only thing the heads are good for is either selling, reusing on the 25, or slapping onto a 22 and turboing it.
You mean these guys: Those are your sway bar end links. Better just to replace those, no sense in monkeying with the bushings. http://www.ebay.com/itm/NEW-SUBARU-REAR-SWAY-BAR-STABILIZER-END-LINK-SET-/120657669782?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1999%7CMake%3ASubaru%7CModel%3ALegacy&hash=item1c17c1ee96&vxp=mtr
Easy way to test your ac circuit is to jump the pressure switch plug with a paperclip. If the clutch engages, you have low pressure in the ac system and need to find and repair the leak, and get the system recharged. Pull the plug off the dryer (Cylinder mounted to the passenger strut tower) And jump the plug. If the clutch engages when you do that, it's an easy fix. (See above)
Snorkus
Yeah, the snorkus is a crucial part of the MAF system. MAP cars can get away with an aftermarket intake, but without a tune, MAF based cars run like crap without the snorkus. My car came without one, and fell on it's face after I built my frankenmotor. Slapped a snorkus on and it pulls hard through every gear above 2k rpm.
I have a Frankenmotor. EJ25D block, single port 22E heads, Delta cams, Grimmspeed phenolic spacers, 300cc DW injectors, port matched heads, Cometic "hybrid" head gaskets shaved .010 under, 10mm oil pump with 2 shims, 2" header, and some other stuff. Another build similar to mine put down about 175 WHP, and he was a little lower compression than me. Basically a brand new engine. Ended up with all new internals, new valves/springs/retainers, etc. About 7000 miles in now and I average 22mpg on the hilly freeway/in town, 26mpg on flat freeway, and have yet to have anything with less than 8 cylinders or a turbo beat me. #1 rule: Don't screw with your intake.
Sounds like the rear shifter bushing. That little "peg" at the far right of the picture goes into a bushing bolted to the tunnel. Usually side to side play is a result of the "fork" at the left having worn bushings. If you end up needing to replace that, I highly recommend a kartboy shifter bushing.
