Everything posted by greg454
Starts; but let the key go to run position(dies)
greg454 replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know on older cars that is a symptom of the ballast resister being bad. When cranking, full battery voltage is fed to the coil for a stronger spark when starting. After the ignition returns to run, the coil is powered through a ballast resister lowering the voltage at the coil as not as strong a spark is needed. So with a bad ballast resister the car will run in "start" and die in "run" key position. Disclaimer... I dont know what car you have or if it even has a ballast resister or not. -
They did in fact have seat belts in the back for the jump seats! I still have them in my '84.
Brake fix it question and help with vacuum hoses
greg454 replied to Lastnoel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My hill holder was also leaking. I removed the cable years ago and it has not leaked another drop. -
Barrett Jackson January 2019 1987 sold for $16,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616495 1983 sold for $12,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616452 Hopefully these links stay active for a while... Think Ill hold on to mine for a while!
Compiling database for Gen2 Brat sales evaluations
greg454 replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Barrett Jackson January 2019 1987 sold for $16,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616495 1983 sold for $12,000 https://www.proxibid.com/asp/LotDetail.asp?ahid=10600&aid=155490&lid=45616452 :-) -
I bought a set of Gen 2 from ebay about 5-6 years ago. I got a full set but only used the "BRAT" stripe over the cab for a little more minimalist look. If I remember correctly I had to pay a little extra because I wanted gun metal gray instead of one of the offered colors. Mine still look great to this day but my brat has always been garaged so that really helps. I would definitely recommend them. Luckily I had a friend that used to apply decals to company vehicles help me as getting them to fit correctly over the cab does take some skill!
Help with '81 Brat Smog Sticker - picture, please?
greg454 replied to bendecker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't know if this helps or not ..EA81, 1984 Brat, 1800, solid lifters,.. high altitude kit,... -
These are a few of my favorite BRATs
greg454 replied to eatmorepossum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha.. Mine made it in 4 different times!! -
My hill holder would leak brake fluid when the cable actuated it. So I disconnected its cable from the clutch fork and have been running that way ever since with no problems. It doesn't leak a drop this way and if I'm on a really bad hill I can always use the hand operated emergency brake, although driving a clutch all my life that really isn't necessary. Also, most drum brakes (I assume subarus are the same) usually have a short shoe and a long shoe. Make sure the short shoe is towards the front and the long shoe is towards the rear of the drum or you may get the kind of symptoms you describe.
- 17 replies
- 1
May be wrong place to post Transmission question
greg454 replied to barngem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
upload your pictures to tinypic.com Its free. After you upload it will give you the new link for uploading to message boards Just copy that link and then paste it here and your picture should show up. -
Subaru Brat ea82 turbo bastard project
greg454 replied to cookiemonster131's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It brought $4950 on EBay. Someone will have fun with that thing -
83 Brat - No ECM and failing emissions
greg454 replied to spatulaisgod's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a problem initially trying to pass Colorado smog test with my '84 brat. They insisted it was supposed to have a computer and o2 sensor and wouldnt listen to me when I told them it never had a ECM. After about an hour with the manager he figured out if he looked it up in his computer as a Subaru truck (he was looking under car) it then showed correctly on his computer and it passed with flying colors. Next time I went back I told them to look it up as a truck and they found it just fine. -
Axle REALLY tight going through new wheel bearing.
greg454 replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I clean up the axle and give the surface a thin layer of oil. It seems to help it pull through the bearings easier. -
greg454 replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is awesome !! -
Help Needed. Gas + Spark does not equal start?!?!
greg454 replied to tundrabrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try to spray some starting fluid down the carb just to be completely sure its not a fuel issue. -
Prep tips for Running in Cold Weather
greg454 replied to tdodge41's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have an hitachi carb and mine starts great in cold weather. If your carb is in good shape are you "setting" the choke correctly? First thing you do before you try to start it is press the gas pedal all the way to the floor and then release it. That sets your choke and fast idle. When the car starts it will fast idle around 2000rpm or so until you blip the gas pedal again and then the idle will drop to normal. Most older carburated cars worked like this and the hitachi does also if in proper working condition. Greg -
I have some pictures in this thread.. Kinda hard to see.. http://www.ultimatesubaru.org/forum/topic/141474-installing-bed-seats-in-a-1987-brat/page-2
4wd indicator switch - where to get a new one?
greg454 replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks. I needed one also so I just ordered one from rock auto. http://www.rockauto.com/catalog/moreinfo.php?pk=943375&cc=1267725
