spikemike203
Everything posted by spikemike203
  1. i do not kno what jets they are i just got the kit from redline for the ea82 and threw it on there im in florida so idk 20 feet above sea level lol
  2. This is Probly true I forgot to mention I have a universale 4-6 cylinder fuel pump, it's Probly flooding the motor, what kind of regulator did you get?
  3. Hooked up choke made sure it had power and the same thing happens, under stress it bogs down and stays bogged until I lift my foot up off the peddle then it goes,
  4. i just thought the choke helped restrict airflow when the car is starting cause its cold, its like 80+ here
  5. I finally got the oppertunity to go out and try my latest mods on my 87 ea82 gl, new weber carb and snorkel adapt. i just put a crappy pepboys cone filter on there for the test. wen going threw sugar sand (floridas finest) it would bog down and go the a crawl if i didnt keep it above 2200 rpm, if i floor it to long up to 4500 rpm it will spuder SOMETIMES, never in first just in 2-5 i had to keep my car in a 2300-4500rpm rang witch kind sucks cuz one the road its quick i can feel the power (what little it has), no problems, under stress i think it gets too much gas? my choke is not hooked up is tht a rason? (the snorkle stops were a fuel injected airbox would be)
  6. my vacuum is all messed up i dnt kno what to plug or not plug, help!! it idles real rough sometimes and then ill rev it n it will be fine, when i rev it up it takes a while for my car to settle back down at 1000 rpms, it declines very slow, any advice?
  7. i had to cut the first coil off them, there would have been no travel they fit terrable, im not to sure i like the way they sit all crooked n ************, if i had to redo it id look for something else i ordered the cc852 like everyone said, n they look terrable, they work, for now
  8. some times its the simple things tht really get me caught up, some how in taking everything off i managed to pop my ignition fuse, i still have all my stuff for injection, maby once i get sick of dealing with the carb ill switch back but for now lil rew is running happy again =)
  9. i dnt want to put injection on i switched it from injection to carb because of computer issues, i pored gas down into the carb not even a spudder
  10. Just installed the weber on my ea82 n it initially started for a second, (probly left over fuel in the intake) and now it will not start at all, any one have good advice
  11. i orderd ford tempo springs moog cc852 for the front i have a ea82 gl on a 6" sjr lift do i need to cut these springs to make them the same size as the ea82? or leave them as is, im hopeing the new springs will lift the car up a little higher
  12. Thank you for the link about suspention it was good help!
  13. i live in florida i may just take it completley off, i do not really care about the tank lol, so ill figure it out when it comes i just orderd it for $331.00 at http://www.carburetion.com/Weber/Dataresults.asp
  14. wow thanks tht isnt so bad lol thank you so much for the link and your time mike
  15. Before i go and order the weber can any one tell me why they say it will not work with a ea82 with power steering with out a mod, and what is tht mod? thanks!!!!
  16. it was the spark plug wires buy the distributer cap so i got delectro greese n new wires, thanks a bunch
  17. thanks 987687 i will try it out, it has new wires n boots i will check the distributor and other electricle components. thanks again
  18. I have all vac. lines running to air filter were else could it be getting wet, the air box is dry inside,
  19. how did you get your car to handle water, every time i spash mud and water to much it goes into a miss fireing funk
