2
upnorthguy last won the day on November 4 2019
upnorthguy had the most liked content!
About upnorthguy
- Birthday 07/14/1971
Gender
Not Telling
Location
Minneapolis, MN
Occupation
legal pawn
Biography
Previously owned: '95 Legacy LS wagon EJ22 4EAT, '86 GL-10 4dr, '87 GL wgn, '88 DL wgn, '90 Legacy wgn and grew to love the snow handling of Minnesota winters...but not the salt induced corrosion!
Vehicles
2001 Forester S
upnorthguy's Achievements
Subaru Fanatic! (6/11)
47
I did have the cam position sensor unbuckled when I was replacing the fill tube o-ring and valve cover gaskets, so I popped it off again and cleaned a bit of residue from the connections and reconnected to make sure it was solid. That seemed to solve the P0340. I followed the FSM info on checking the resistance of the primary and secondary connections on the ignition coil. The secondary (across 1 & 2 contacts and 3 & 4 contacts) checked out within the range in the FSM, but I was unable to get any resistance readings through the primary pins combos (1 & 2 and 2 & 4). I went to a salvage yard today and checked a couple of coil packs there, there were two that mimicked the same behavior (secondary resistance within range, unable to get any resistance readings across primary pin combos). I bought one of the coil packs and fired up the Foz a couple of hours ago and no codes are coming up and the engine runs smooth, so there do not seem to be any misfires. One test drive was without trouble. I'm going to take it on a few more spins around the 'hood and make sure it does not pop codes again. Interesting problem with an interesting assortment of suggestions. Thanks to all for the input.
Yeah, I have an OBD reader. No codes to start. I tried starting it a bit ago and it was turning over, but wouldn't catch. I tried a few times and got it go after giving it some gas, but it was tough. Checked codes tonight and got P0301, P0340, and P0302. Very strange, as it had no trouble turning over last night and did not run rough. Definitely shook more tonight, which makes sense if I'm getting a misfire on cyliners 1 and 2. I have no idea why the camshaft position sensor would now be kicking a code.
Hey gang! Long time. I did some searching and didn't find what I was looking for, so... My 2001 Forester (I got it with 153k, it has 178k now) started with some flashing CEL and rough running ("the muffler was banging"), causing the mrs to smartly circle back to the compound and park it. I've done some digging on the Google and it looks like this is likely tied to a misfire of some kind. I replaced plugs and wires with new NGKs (along with new valve cover gaskets and a new fill tube o-ring as there was a decent amount of oil buildup on that side of the engine). Took it for a test drive and all seemed fine- no flashing CEL, ran like normal. A few days later, I fired it up to take it for another spin around the neighborhood and the CEL was flashing right away and exhaust smells rich. What should be my plan for trying to chase down the misfire? Check ignition coil pack next? What about after that?
I'm guessing someone smarter will chime in, but you can do some comparison on opposedforces.com and match part numbers. You can also do a similar maneuver by looking for the part on an auto parts site (e.g., Advanced Auto). Assuming you are going to get a used knuckle from a salvage yard, have it include the ABS sensor if you can. Removing your old ABS sensor to reuse almost never works as they get frozen into the knuckle and you end up breaking it while trying to remove. I've had success with $15 ABS sensors from eBay.
Had a used 4EAT (with ~80k) installed on my 2001 Forester a month or so ago and it has recently started flashing the A/T oil temp light. Did the handshake today and I think it is code 78 SPORT shift solenoid - detects open or shorted output signal circuit.. I'm not finding much on this. Can anyone smarter shed some light on this one for me? Is this internal to the transmission? Anything external I can check?
First shop diagnosis confirmed my hunch that the front diff is toast on my 01 Forester. Quote for installation of used transmission was crazy. Anyone near me with transmission swap experience up for a Saturday or Sunday fun day? All the beer and food you could consume plus some bucks for your expertise! I'm mostly of up for the challenge (although the mrs is trying to rule against me). I had the EJ22 out of my old gen 2 Legacy, but no transmission work yet. Having an experienced pilot to help this co-pilot along would definitely help.
If autopsy pics become available I will certainly share! Update: No "open body" autopsy was done. Diagnosis was likely a bad pinion gear (or more) and the entire transmission was swapped.
- 44 replies
- Drive shaft
- Axle
(and 4 more)
Tagged with:
Definitely not driveable more than a few feet without feeling like one of the wheels is going to fly off. The clunk is very significant. I had it towed home (I realize my statement that I "got it home" was way too generic!). For shiz and giggles, I'll install the FWD fuse later and see what happens. After searching for a decent walkthrough of the 4EAT removal/install, I just finally found it in the FSM (it was in the engine section, not the transmission or transmission/differential). I think I'll be in the market for a used tranny. I think best fit is a 4EAT from a 00-02, right?
- 44 replies
- Drive shaft
- Axle
(and 4 more)
Tagged with:
I think my 01 Fozzy just developed this. Daughter was driving it yesterday and big clunk, then a big clunk each tire rev that got worse apparently. Got it towed home. Jacked it up with all four wheels off the ground and in drive to do some testing and without engine load there is no noise. Spinning the wheels by hand does not generate the clunk. Once you give it some gas (~2k rpm) the wheels spin with enough power to feel the clunk. I thought it sounded like a bad inner CV joint on the passenger side. I replaced the passenger half shaft and the big clunk is still there.
- 44 replies
- Drive shaft
- Axle
(and 4 more)
Tagged with:
I'm with Caboobaroo on this. I've replaced a couple of units with salvage linkages without having to mess around with the Dorman type replacement parts. I check the linkage at the yard before I remove it to see how tight they feel with regards to slop. So far I am 2 for 2 on good replacements. This time of year, an ebay linkage can work nicely too...warmer for the hands.
Ah, that helps explain why my ABS light was on (but has subsequently gone out). Of course I had packed up the stands and moved on to some other projects. Rejacked/standed and tested. Throttle increase does cause rear wheels to spin. I guess the spin I feel at the front wheels is the initial slip before the rears have kicked in as the throttle increases. Seems like this feels different compared to the 95 EJ22 I had (I don't recall it having the same amount of front wheel slip during a slippery start from zero). Maybe a little more torque/HP with the EJ25 causes that? Thanks for the clarification on my misunderstanding of VC/center diff (or lack thereof) on the AT.
