Ravenwoods
4
Everything posted by Ravenwoods
My daughter bought a 1995 Impreza (EJ18) with the ABS light on. Brakes work great. Now that winter is here I thought maybe we should see if we can fix the ABS. I know nothing about the ABS system, only that each wheel has a sensor. The car has 178,000 miles on it. How do you determine where the problem is?
Temperature was up to about -10 today instead of -45 when the oil leak happened. I drove the car about 50 miles today without a repeat. I suspect the pvc valve froze shut and pressure built up and forced oil out the dipstick. It may have been only a cup, but a cup of oil can make quit a mess. Anyway I replaced the pvc valve just now. The old one looked elderly. Does that scenario sound plausible?
Not at the minute. I put it outside in -36 temperature and it is dark now. But when I started it up to take it out of the garage there was no leaking. Engine ran normally no sign of a leak anywhere, no oil dripping on the ground. Everything appeared normal. We changed the oil about 500 miles ago but did not overfill it.
I drove my daughter's 1995 Impreza in -40 F weather today and after a few miles there was a very strong odor of oil. I got it home and in the heated garage. Oil every where on the left side of the engine. The engine oil level is down a bit, not more than 1/2 quart. This is a 1.8 liter engine I believe. The engine didn't make any unusual noise. If it were a head gasket I think one might hear something or have less power. So maybe some other oil seal has failed like a valve cover seal? Just wondering what people think might be the most likely cause?
The oil pan heaters we have here in Fairbanks, Alaska are a thin sheet of rubber with heating elements embedded in it. A cord comes out of that. You just get some high temperature silicone sealant from the car parts store and clean off the bottom of your oil pan real good with some degreaser. Glue it on and they last forever. I've never had one go bad. That is best way to handle it. If you have -40 right now and the power cycles on and off every fifteen minutes, I'd just plug it in before you go to bed. That would mean it would be on four hours and that is just about right at that temperature. Here is a link at amazon to a 50 watt heater: http://www.amazon.com/Kats-24050-Watt-Universal-Heater/dp/B000I8YPQ4/ref=sr_1_6?s=automotive&ie=UTF8&qid=1387772661&sr=1-6&keywords=oil+pan+heaters I don't remember what wattage I have on my vehicles, but 50 watt sounds about right. You can get much more powerful ones for large vehicles such as a big kenworth.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Whenever I get a replacement battery, I don't go for the biggest or most expensive. I just go for the middle of the road battery. If you plug your car in and have an oil pan heater, your engine will spin over very nicely. Also with the warm oil, it cuts down on engine wear very much. Just a couple weeks ago we went to Chena Hot Springs resort for the night. They are not connected to an electrical grid and so have to produce their own electricity through geothermal processes. So they only have a limited number of places for cars to plug in. When we got there we could not get parked in a spot where we could plug in. I just replaced our battery last August as it was about five years old and showing signs of not being as strong as it used to be. The temperature was about -25 F and the next morning early I went out to see if there were any empty parking spots so I could move my 1998 Forester (215,000 miles) to a place where I could plug it in. The car had been sitting overnight for about 14 hours and the engine and oil were totally cold. I just barely got the car started. I moved the car and plugged it in. Six or seven hours later when it was time to checkout of our room, the car started as if it was summertime. This is how dramatically effective a block heater and oil pan heater are. This really does reduce wear and tear on your engine.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Heet can be useful if you live in a warm wet area like Seattle and you travel over to a colder place such as over the Cascade mountains to Eastern Washington where it can get colder at night. Sometimes moisture in your fuel can cause problems and putting in a can of heet before you drive over can help.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Plugging in your block heater and oil pan heater all night is totally unnecessary. The electric company says that in extreme cold weather such as 50 below, that plugging in for more than four hours is wasteful. Usually 2 hours is plenty. You can get a timer to set so that the extension cord is energized at a certain time. Also there are kits you can install on your car that turns the block heater and oil pan heater off once the block has achieved a certain temperature. As far as sludge forming because of an oil pan heater, that is nonsense. Every car in Fairbanks has one. I change my own oil all the time and no sludge every comes out. The oil pan heater would need to get hot enough to burn the oil to create sludge and that just is not the case.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Check to make sure the block heater is actually functioning by putting your hand on the block near the block heater to see if it is warm. Here in Fairbanks, Alaska, they urge everyone to plug in their block heaters and oil pan heaters when it is 20F or colder. A warm block greatly reduces the amount of unburned hydrocarbons your exhaust pipe puts out into the air. We get temperature inversions here that trap pollutants in air and the air can get quit bad. The oil pan heater really helps the engine to spin over nice and fast and reduces engine wear at those low temperatures. If you cannot find one in the stores there, let me know and I can mail one to you. You just use some silicone sealant to glue it onto the bottom of your pan.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
An oil pan heater pad and engine block heater are more important than a battery warmer. Here in Fairbanks Alaska we routinely get cold temps like this. I used to have the battery heater also, but as long as your battery is healthy and you have a block heater and an oil pan heater, your engine will crank over easily and start pretty good. Will run rough for a bit and make all kinds of aweful noises. This is if your engine is well maintained. Ours has 215,000 miles on it and still going. But fortunately we have a warm garage for it to enjoy at night.
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Thanks for the help. I found some pictures online of where the purge valve is and Napa has a nice picture of the part: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Canister-Purge-Solenoid/_/R-CRB2283725_0347584587#Full0 Found it on my car. Looks like one bolt is holding it on. Since I cleared the code from my car on Saturday night the check engine light has not come back on. I interpret that to mean it is not a leak from rust or a cracked rubber tube. This seems to point to the Purge Valve or Evaporative canister itself. Most likely the purge valve acting up from time to time. The check Engine light only came on about two weeks ago and then went out by itself, before coming on again. Will a faulty Purge Valve cause the intermittent rough engine idling I have noticed? It is not that noticeable since my wife had never noticed it. Anyway, this morning while dropping my daughter off at the school bus stop, I did not notice any of the rough idle episodes.
I took the plastic shield off of the filler tube and there was only a bit of dirt. Some rust but not too much, mostly up around the top and on the smaller pipe that connects to the rubber hoses to the canister. Took a small wire brush and cleaned it up a bit. When I took the gas cap off, there was the standard vacuum sound you get when you take off the cap. I opened the hood of the car and looked for anything that might look like a purge valve but did not spot it.
Heating bill is not so bad since I heat with wood that I gather myself. Huge amount of work every summer to get 11 or 12 cords of wood to heat garage, house, and all our domestic hot water. We have one of those wood burning boilers that is connected to our oil burning boiler. But it helps keep this 53 year old alive. But since I heat with wood I turn the thermostats up to 74 or 75 and we have floor heat so the floors are nice and toasty and our cat worships the warmest floor spots. Yes, we have a block heater on the Subaru and an oil pan heater. Some people even have a battery warmer. But if your battery is strong, it really isn't necessary if your block heater and oil pan heater have done their job. The engine will crank over nicely at 30 below. My diesel truck has a spot on each side of the block for a block heater and I've been tempted to put in a second block heater for really cold days like 30 or 40 below. At night it is in the garage, but after being outside while I'm at work for 8 hours, it runs pretty rough for 15 seconds when I start it up. I'll check the connection to the canister to see if I can spot any problem and maybe get a new gas cap. Last summer I left the gas cap on top of the car after filling it up and drove off. While going down the freeway I heard something rolling off the car and saw it hit the pavement in my rear view mirror. Later on I returned on my motorcycle to look for it and found it. Also got a bonus: a very nice ball thrower for our dog. Apparently someone left it on a car bumper or something.
