Ravenwoods
4
Posts posted by Ravenwoods
We have a Forester S with 323,000 miles on it, and looks like it too. But the engine is still strong, doesn't seem to burn oil, but of course leaks oil.
New clutch put in about 150,000-160,000 Miles ago.
So the clutch is still strong. In past summers when we had lots of temps in the mid 80s or higher the clutch pedal would act strange. You could push it down but then need to pull it up again with your foot. So this only happens in hot weather and after the car has been driven a awhile and all the parts in the clutch system are thoroughly hot. So yesterday was one of those days but this time it was worse. Almost impossible to get it into any gear when the car is stationary. Once you get moving then you can manage.
And of course today when the car has cooled down the clutch is back to normal.
So there must be some need to make a clutch adjustment. When you have to pull the pedal back up, you can feel that a spring somewhere gives resistance about half way up the pedal stroke, then decreases after that point. It is almost like you have exceeded the springs correct depression.
Any suggestions on what to do?
On 4/28/2023 at 2:03 AM, lmdew said:
Hopefully Dad has an OBDII reader for her and has taught her how to use it. Easy to clear.
So sounds like the best approach is to ignore it?
On 4/27/2023 at 9:50 AM, 1 Lucky Texan said:
6 cyl or 4cyl?
scan for and make note of any other codes including 'pending' codes. Clear the codes and see how quickly the P0420 comes back and any other codes as well.
many people jump to changing the cat conv (and of course they do go bad) but, that code can be caused by exhaust leaks, vacuum leaks or bad wiring. The code on the 4 cylinder cars is only a 'nanny' code intending to monitor cat efficiency but is NOT used to alter any air:fuel ratios or other operating parameters.
Its a 4 cylinder 2.5 liter.
My daughter drives the car only for short trips. I suspect some of the problem is she never takes long road trips. I borrowed the car last month to take a 140 mile trip to test drive the car. No check engine light the whole day. But as soon as she started driving it again the light has been on the whole time.
6 hours ago, Ferret54 said:
When we had this code on our daughters 2001 Outback ( 2.5L ), it was 10 years old. No exhaust leaks. Tried rear Oxygen sensor, still P0420. So I purchased an extender. Had to drill out the center for the Oxygen sensor to fit, then installed it. Takes rear sensor out of the flow. No more P0420. It was still on the car when we sold it 2 years later.
I have no idea what an extender is.
My daughter's 2000 Legacy has the Check Engine Light on and the code is P0420. Something about Bank 1. Automatic Transmission. About 180,000 miles.
So is the code referring to the Oxygen sensors on the Catalytic Convertor? One upstream and one downstream from the catalytic converter? Or is this somewhere else? The car is running normally with good gas mileage.
1 hour ago, lmdew said:
Normally you can find used or new parts on ebay for reasonably prices but nothing came up. Rock Auto also doesn't have this part. There are other sources online but the prices are $80 or more. I might try the local car junk yard. Or I could swap out the one on my 95 Legacy with her 95 Legacy and see if I get a P0400 in my car.
3 hours ago, lmdew said:
Valve and line are fine. Could still be the control valve or vaccum hoses.
None of the vacuum hoses are cracked, but the rubber is old. So maybe the old rubber results in a less than perfect vacuum? What is the control valve?
I found a non-automotive hand vacuum pump that did the job. So at idle when I connect the hand vacuum pump to the EGR it causes the car to idle very badly and almost die. So I guess that means the EGR is working fine? Maybe the system just needed cleaning. I'll get the car insured and take it for a 50 mile drive and see if the P0400 code comes back and see if the gas mileage is back to normal.
On 9/7/2022 at 5:36 PM, Ravenwoods said:
I found it, a vertical tube about 12 inches long. Nut takes a 17mm wrench. I sprayed some PB blaster fluid on the top one as it doesn't want to turn. It's such a thin nut I'm afraid of the wrench slipping and rounding the nut corners.
Okay, the tubing spanner or the flare nut wrench arrived this morning and I got the tube off this afternoon. The tube was not blocked and looked rather clean. No partial blockage either. Perhaps with all my cleaning perhaps I've solved the problem. But I would like to make sure the egr solenoid is working. Seems like I saw somewhere how to test that. Also Someone recommended testing the egr with a hand vacuum pump while the car is idling to see if the egr works.
49 minutes ago, heartless said:
yeah, flare nut wrenches.. commonly used for brake line work..
probably could have gotten a whole set locally for less money with shipping and all.. most auto parts stores should have them.
It was a Craftsman for $6.95 and free shipping.
2 hours ago, lmdew said:
They can be very tight. I've used a tubing wrench. The flat 6 sides work well. In the yards a vise grip works. Before you go to the trouble of removing it, do the troubleshooting using a hand vacuume pump to open the egr with the engine at idle.
I was thinking I should get a tubing wrench but didn't know the name for it. So I searched Ebay and lots of tubing wrenches from China, England and Australia. So that gave me a clue that maybe they go by a different name here in the USA. Seems they are known as Flare Nut wrenches in the US. Lots them show up in Ebay with shipping from the US. So I ordered one.
4 hours ago, lmdew said:
The head or tube may be blocked.
What is the head? Which tube are you thinking about? So you traveled up from the lower 48 to do halibut fishing? Or you decided not to to go halibut fishing because rentals were too expensive? Did you look at cars on the Turo car rental place?
My daughters 95 Legacy, Automatic Transmission, almost 190,000 miles, has had the P0400 code for some time. Comes back almost immediately after I clear it. Engine idles fine, starts fine, runs fine, but very poor gas mileage (140 miles used 3/4 of a tank).
So I removed the EGR and transducer yesterday and have been cleaning them. The transducer has a little removeable cap with a spongy filter there and I cleaned that too. I can depress the valve on the EGR and put my finger on that vacuum tube connection and it hold the valve open until I remove my finger.
None of the tubes or hoses appear to be blocked. The all seem open.
So what about the EGR solenoid? Is there a way to test if that needs replacing? We are preparing the car to sell since she recently bought a 2000 Legacy.
My daughter just bought the car for $1850. The owner volunteered to lower the price from $2000 because the Auto-Start stopped working and she hadn't been aware of that. Now our youngest daughter has the newest car. Now she well sell her 95 Legacy. Our eldest daughter has a 96 Legacy with only about 150,000 miles on it. My wife has the 98 Forester that doesn't want to die. I have a 95 Legacy with 207,000 miles on it and a 97 GMC 2500 truck. At one stage I had two 95 Legacies just for me, so we had three 95 Legacies all at the same time. I had picked up my second one for only $400. It needed lots of work so I fixed it up and then sold it for $1100.
Currently my 21 year old daughter is serious about the car. The owner hasn't advertised it online yet, as she is giving us a few days to decide on it.
9 hours ago, idosubaru said:
That’s a great price for that year and model Subaru with that maintenance history. Around here any old beat up subaru with no records and 200k miles would sell for $2k quickly. If it was local I’d buy that for a guy I know that’s looking.
Id buy it and install a new Subaru timing belt, Subaru lower cogged idler and run it. Those are the two most failure prone timing components that lead to bent valves if they fail.
1. Headgaskets. 2003 is 10 times better than a 98 forester engine. Thats the single worst year forester engine by a long shot.
2. The 2003 original gaskets will usually start to leak coolant externally *very slowly*, gets worse over a long period of time (years), and causes no drivability issues. Sometimes oil, also externally, but usually coolant. You can literally top it off with teaspoons or coolant for many years and 100,000 miles usually. When they first start leaking it’s just “seeping” out, causing the metal to get discolored, not even pooling up or running or dripping. Most owners never notice it but a shop points it out. So these aren’t alarming head gasket leaks.
* what you don’t know is if they’re original gaskets or how long it’s been leaking - but these are forgiving and not prone to catastrophic overheats or engine engine.
3. If it’s external coolant then immediately go to Subaru, buy a bottle of Subaru coolant conditioner and follow the directions. That stops every single initial leak of the factory installed headgaskets 99% of the time. We don’t know that these are original factory gaskets or if they’ve been leaking a long time, or even if it’s coolant or oil, but if it’s coolant (usually is), it’s worth a try for $5. Additives in general *suck* and should be avoided. And this Subaru conditioner should be avoided too on an ill running, questionable cooling system. but this one sounds in good order and a proper use case for Subarus coolant conditioner.
bottom line these engines are very forgiving if it’s original gaskets or they’re properly replaced. And they usually give you many 10s of thousands of miles to plan a repair.
Usually an owner wants to repair it because it’s dripping and staining garage floors or smoking off the exhaust, not for overheating, engine damage or getting stranded.
Id wait to see how bad the leak is and wait to replace headgaskets until you have symptoms that warrant it. A 2003 with a seeping gasket is no big deal, if it’s worse then yeah start planning.
Make sure it’s done right with Subaru gaskets but it sounds like you have that covered
Valve covers are easier than timing belts so you can easily do those. Have a ratcheting 10mm wrench for the rear lower valve cover bolts.
This is a 2000, bought in 2003 by the current owners. She said there is a maintenance record indicating a Subaru Recall where they replaced the head gaskets, I presume this was done by the first owner.
This car has an automatic transmission and 176,000 miles on it. A decent set of summer tires as well as a great set of Toyo winter tires, both mounted on rims. The current owner is the second owner (since 2003) and has a complete history of maintenance done by a local shop here in Fairbanks, Alaska with an excellent reputation for working on Subarus.
We don't get the corrosion here typical of other areas such as the lower 48 where salt is used to de-ice the roads. Salt is not used here so the car has little corrosion. The body looks fine. It has a new windshield too.
My daughter currently has a 1995 Legacy L that works fine and has close to 190,000 miles on it, but is cosmetically challenged, with quite a bit of corrosion, and the ABS brakes don't work. She only drives about 3000 miles annually (probably less), dislikes driving, and never drives any significant distance, rarely if ever more than 30 miles away.
So with the 2.5 engine from this era, I understand the head gaskets are the weak area. We do have a 1998 Forester S that we have had since about 2003 that currently has 316,000 miles on it. We had the local shop do the head gaskets and valve seals at about 160,000 miles and the car just keeps going. To be fair, the previous owner did set it up for towing behind an RV and they said about 50,000 miles on the odometer are towing miles. So the engine might only have 260,000 miles on it or less.
So my main concern about buying this car are the head gasket issues. The engine is a SOHC. Our Forester has the DOHC. So I'm not sure if that makes a difference concerning the headgaskets. As far as my car repair skills, I have replaced all the timing belts and pulleys on the family fleet of four Subarus and changed out the CV axles when needed. But I've never replaced head gaskets or valve cover seals. So if we did buy this car and the head gaskets needed to be replaced I'm not sure about doing that myself. Would be worth it to replace the head gaskets on this car? The owner did take it to the local shop for an inspection before advertising the car to be sold. They did mention there is a head gasket leak.
The owner isn't sure what the car is worth but mentioned $2000 as what she had in mind.
EBay has an OEM sensor for $9.79
We changed the timing belt, pulleys, water pump about 20,000 miles ago
Last night my daughter reported her car died just when she got home and wouldn't restart. This morning I dropped by and it started right up and there was a code for Crank position sensor malfunction. I cleared the code and took the car for a test drive. No problems.
Should we just preemptively replace the sensor or wait and see if the problem repeats?
Car is automatic transmission, wagon, less than 200,000 miles.
1998 Forester clutch pedal in "hot" Alaskan weather
Posted
It does have the hydraulic clutch with brake fluid in it.
