Ravenwoods
4
Everything posted by Ravenwoods
My daughter’s 95 Legacy (180,000 miles) had a misfire on cylinder 3 yesterday at about negative 25 Fahrenheit or colder. We plugged it in longer this morning (5 hours instead of 3) and it was worse this morning. We got misfiring on cylinders 3 and 4. We evicted my wife’s 98 Forester (almost 299,000 miles) from its coveted spot in the heated garage and put the Legacy in to enjoy some tropical weather and get thawed out. It’s really amazing how much of a difference this makes for cars that spend most of the winter out in cold, to have a periodic thawing out. Anyway, I took the spark plugs out (Installed 2019). They are NGK BKR6E. Only one looked a bit dirty—passenger side rear. The front one on that side looked a bit dirty too. We also replaced the wires in 2019 so I haven’t checked them for resistance. So at one stage my other daughter brought home new spark plugs for her 96 Legacy: NGK BKR6E-11. I think they are viridian. Anyway the engine rain smooth on those plugs but kept causing a misfire code, maybe cylinder 3. So we put in the standard NGK plugs: BKR6E. No more misfire code. So I am wondering if the BKR6E-11 with the viridian electrode might work better in cold weather? Or another NGK plug? Any thoughts on this? I decided to put them in as an experiment. The weather is forecast to be warmer tomorrow: warm up to -15 by tomorrow morning and get up to a tropical negative 7 by the afternoon. Then colder again Thursday-Saturday.
These oil pan and transmission pan heaters are not designed for any specific vehicle. It’s just a thin sheet of rubberized material with heating elements inside. You put some silicone adhesive on one side, and adhere it to a cleaned area on the metal pan. You can get different wattages depending on how large of an oil pan you have.
Thanks! So my car starts normally and engine temperature comes up nicely and is normal. Just the code and the poor mpg are the symptoms. This sensor is the one under the Idle Air Control valve on passenger side of engine? Some people (not many) put a piece of cardboard in front of their radiator. Those people might just need a new thermostat. Our cold snap is coming to an end this weekend. It was only -26 this morning at my house. Sunday expected high is -22 and Monday -7.
I have been getting an occasional P0125 code and after researching it yesterday it sounds like my ECT sensor is likely going bad. My MPG is down from last summer (about 24 MPG) and I assumed it was just winter weather. Its been running about 19-20 MPG but yesterday it was 15.21. We have been enjoying a nice cold snap in the negative 30s Fahrenheit so that would have some effect on MPG but it doesn't effect our 98 Forestor this much. I'm planning on dropping by Napa this afternoon to pick one up. Any suggestions on what Brand I should aim for? I notice there is also a Temperature Sender Switch. Is that the same thing?
My 95 Legacy with AT has 191,000 miles. In cold weather (15 f or colder) it takes a mile or two for the transmission to shift up to the fourth gear. The colder the weather the longer it takes. This morning at -30 it took nearly 3 miles. Is this a sign of a transmission getting ready to fail? My daughter also has a 95 Legacy with AT. Her car has a AT pan heater. So maybe this is a common problem with the Legacy AT? I've been thinking I should get the heater for my Legacy too.
I put the legacy in my heated garage after work yesterday and took off the brake booster line. But I did not catch the part where you said the valve is in the rubber hose rather than where the hose connects to the black contraption on the firewall. Anyway I sprayed some MAF cleaner in there and in the engine manifold, but not in the hose. Anyway, some of the MAF cleaner must have ended up in the hose since there were no braking problems this morning.
I got them from Rock Auto, an online business. Are they considered reputable? Anyway, yesterday afternoon after work, my car had been plugged in for 8 hours. Standard winterization here is an engine oil heater and a block heater. Some cars also have a battery warmer and and heater for the Automatic Transmission fluid. So it started nicely at -38 F with no misfires. It had been plugged in for 4 hours before I started it yesterday morning. So it seems to like the 8 hours of plug-in time much better. So I plugged it in last night for about 8 hours. No misfires this morning. Also it has warmed up to a balmy -30.
Here in Fairbanks, Alaska we are currently "enjoying" some cold weather down in the negative 30s. My 95 Legacy (AT) with 191,000 miles runs great when it is warmer that -30, but at this colder temperature the brakes frequently will act like the engine is off, and then suddenly be near normal. This does not seem to be normal even at this temperature. I have to press real hard and there is little braking. Fortunately no close calls yet. At warmer temperature when it is warmer than -20 it will do this first thing in the morning and then be normal the rest of the day. I'm also getting a misfire code for cylinder 2. A few weeks ago when we had our last cold snap I got a misfire code on cylinder 3. The plug wires looked old so I checked the resistance and one wire was real high so I put on new NGK wires. Last summer I put in new NGK plugs. At warmer temperatures I don't get this misfire. At 2500 rpm the misfire appears to go away but at idle it comes back.
The manual for my 1995 Legacy L has a section called: ”Towing with front wheels raised off the ground.” It then says to “Never tow manual transmission AWD vehicles with the front wheels raised off the ground.” Then it says: ”If your vehicle is AWD with automatic transmission put a spare fuse inside the FWD connector located in the engine compartment and confirm that the Front-wheel drive warning light comes on. Release the parking brake and put the transmission in neutral. The Ignition switch should be in the ACC position while the vehicle is being towed.” Under using the spare tire section it doesn’t mention FWD at all.
Three months ago I got a 95 Legacy wagon with AT, my first Subaru with AT. Now that I’ve finished fixing it up (new struts, new tires, timing belt kit, replaced most fluids, fixed hole in exhaust pipe, new climate control switch, replaced blower motor, new spark plugs) the car is running great with 188,000 miles. I looked in the manual to read instructions on the FWD option. It only mentions it in regards to towing the car. I had read on the web some places where people suggest you should use it if you have the spare tire on. Some people suggest it would be harmful to the car if you put it in FWD for the summer for improved fuel economy. So what is the truth about using the FWD option? It seems the manual would give explicit instructions about this if it could be detrimental to the differential.
Well we took the car into a mechanic that specializes in Subarus to get this car sorted out. They said it was a weird interesting case. After a couple hours of labor they determined that it was an electrical problem. They surmise there is corrosion between the transmission and the engine causing a voltage drop. The ground cable from the battery goes to the transmission. So they put on a “bandaid” short ground cable from the transmission to the engine. My daughter reports the car is now behaving normally and appears ready her upcoming road trip from Fairbanks to Anchorage in about a week. Thanks everyone for the advice and suggestions on diagnosing this. I learned a lot more about working on our five elderly Subarus (95-98) as a result of this frustrating problem. It should help me in the future keeping them all going.
Ok, I haven’t had time for a few weeks to try and sort this car out. My daughter has been using my spare car in the meantime. So today I started looking very closely at all the vacuum hoses to see if I missed something. The hose that goes to the PCV seems a bit loose on one end. Could an air leak there cause major misbehaving? If so it might be able to explain the intermittent nature of the problem. Maybe it seals there sometimes and then other times not.
