Ravenwoods
5
Everything posted by Ravenwoods
Ok, I haven’t had time for a few weeks to try and sort this car out. My daughter has been using my spare car in the meantime. So today I started looking very closely at all the vacuum hoses to see if I missed something. The hose that goes to the PCV seems a bit loose on one end. Could an air leak there cause major misbehaving? If so it might be able to explain the intermittent nature of the problem. Maybe it seals there sometimes and then other times not.
I replaced the belt and tensioner today with no improvement. I had already swapped out the MAF with a 95 AT Legacy which did not seem to help. So today I took a different MAF from a different 95 AT Legacy and neither car has any bad behaviors with the swapped MAF sensors. All the MAF Sensors have different numbers on them. Very strange how the problem suddenly disappears from time to time.
We have four Legacies in our family (95-96). I picked up one recently as a backup car that I can fix up. It has a knock sensor trouble code so I pulled the knock sensor today and discovered it has a different connection than the other cars. A big connection just like our 98 Forester. I had ordered a replacement sensor and was going to put it in today. So are the connections not Standard? Should I get a knock sensor for a 98 Forester?
My daughter’s 96 Legacy Brighton (MT, 119,000 miles) has been acting up for months now. There are no trouble codes. I looked at live data with the OBDII reader and noticed Ignition Advance is 14 degrees when the engine is warm and idling. So I Looked at live data from two other Legacies (1995) and their Ignition Advance is 20 degrees when warm and idling. Is this a clue as to what the problem is? Swapped out the following parts from our 95 Legacy to try and find the fault but nothing helps: MAF, Coolant Temperature Sensor, Knock Sensor, Camshaft Position Sensor, Crankshaft Position Sensor, Fuel pump. The problem is rather intermittent. Sometimes real bad and other times hardly misbehaves. It stalls out while driving but the engine doesn’t usually die. It jerks etc. It acts like either suddenly there is no fuel or no spark in all cylinders.
We replaced the coolant temperature sensor but there was no improvement. We still don’t have any trouble codes. So I swapped out the following sensors from a 95 Legacy one at a time with no improvement: Knock sensor, camshaft Position sensor, crankshaft angle sensor. Now I’m planning on swapping the fuel pump too. Any other suggestions?
Thanks everyone for the help and advice. I jacked up the car today and the left cv was broken. I put in a old functional cv axle to test the car out and it drives normally. I bought it for $425. The engine is strong. Check Engine light is off but I attached my code reader and there are 4-5 codes, such as cylinder misfire. I’m assuming new plugs and wires will sort that out. Our family now has three 1995 Legacies, a 96 Legacy, and a 1998 Forester S. So this new Legacy will be the backup car for when one of the others needs work done on it. The Forester needs work now so it’s going to be sitting around for a bit.
I’m in Alaska. The seller was too busy today for me to go over and jack the front up to see which cv is broken. She says Sunday morning will work for her. I told her what the problem most likely is and that it is an inexpensive repair in case she decided to keep it. She just wants it gone as she doesn’t have time to deal with it at the moment.
