Mdarius
About Mdarius
- Birthday 03/16/1971
Location
Sandy, UT
Interests
I break stuff.
Occupation
Project Manager, Supply Chain
Vehicles
2005 Legacy Wagon
Mdarius's Achievements
Advanced Member (3/11)
0
In case this isn't already common knowledge, the dealership informed me today that lube shops often mistake the transmission filter for the oil filter. The oil filter fits, and they put the $4 oil filter on instead of the $40 transmission filter. In my case they crimped the filter housing, resulting in a hole, that drained my transmission. The car didn't start complaining until late in the game, still waiting to see what kind of damage was done. Just a heads up if you don't do your own LOF changes. Is it REALLY cheaper or the same cost to take it down the street to Jiffy Lube? My $350 and counting says no. (2005 Legacy) Codes: P0700 and P1709 Symptoms: Slow to shift in to gear, shifting like your riding the clutch, but it's an automatic, dies when coming to a stop sometimes, I assume it didn't shift out of 2nd. Hope this helps someone.
WHAT!!!! Did you do voodoo on me because I couldn't use the FSM???? Undo it! Quick!! Problems: The last place that changed my oil mistook my transmission filter for my oil filter. Also, when they tightened it down they crimped it, resulting in a leak. I have been running without tranny fluid for how long?? God bless Subaru, but I wish it would complain more than that so I would know before I do something stupid like that! So, this also means they didn't actually change the oil filter...and probably not the oil. It's low and black. Add to it the leaking head gaskets, leaking oil pump, timing belt that needs to be changed, bad CV joints....the list goes on. My poor car has been abused and I didn't even know it! My '84 Land Cruiser is in better condition!!! That's just wrong. I stopped doing my own oil changes this summer because it wasn't saving me any money and it made a mess that I had to clean up...a trip to the parts store to dump the oil. I suppose had I known this would be the result I would have kept doing it. Sons of guns. I was going to sell it this last summer, too. It would have been after the "oil change", but before I knew there was a problem. Better for my pocket book, but somebody else would have hated me, even though I didn't know.
So, yes, I went through all the connections...again. I think I know which ones apply specifically based on the FSM so I checked them twice. The same 2 codes came back after the last reset, in fact, after the leaving the positive cable disconnected for 2 days the codes came back up almost immediately. I'm afraid it's time to call in the real Jedi. I could check one more connection in the console, but I break stuff. If I do that, what would have been a $300 job 3 months ago will turn in to a $600 job 3 months later, and the AC blower will STILL sound Chewbaca! BUT...i got an OBDII code reader and vacuum gauge out of the deal!
you're killin' me smalls!! It's all good. I did read a post while searching the magical interweb that indicated the whole thing (with these specific codes referenced) may be due to the fact I left the battery connected and disconnected the wiring harness, (which I did), tripping a fault. I just don't know how to clear the fault. It's my fault. Admitting it is half the battle. I checked all my connections...with the battery disconnected...they seem tight, no damaged wires, pins and receptacles in line. Thanks for the tip on the yellow one...I was moments away from a learning experience. And yeah, I was trying to find words for the picture with all the connections...and I was simply speechless. Now, to search the FSM...thanks for all the help! (sincerely.)
Thanks, I needed a little humor in this humorless thread. I'll have a look. Any idea which wiring harness? I found this, but not sure I trust it: ''The neutral safety switch has a 12-terminal connector connected to a wiring harness under the dash.'' Fairly generic. When you're in there bent over double in sub-freezing temps, the dash seems like a pretty big place to just generically search for a 12-terminal connector.
