About Padawan
- Birthday 10/17/1990
Location
Norway
Occupation
Electrician
Vehicles
I Love My Subaru
Padawan's Achievements
Advanced Member (3/11)
3
Noticed that when I first saw the ad. The engine was probably toasted and someone then used the bellhousing to hold the flywheel in with the gearbox
Thanks for your help Didn't think it could be EA81 stuff. We got the Brat new from the dealers up to 1992 or 93, so the parts is most likely from a Brat. I want to swap the sad 3AT i my 87 sedan with a dual range, but those aren't easy to find over here.
Came across an ad for a complete drive train for an older Subaru. The seller isn't sure witch model it came from but says he thinks that it's from an 88 model Leone, probably sedan or wagon. But could anyone identify the gerbox? Dual range or pushbutton?
After going through the exploded illustrations in the Haynes manual it seems to me that the caliper would need a rebuild. So a new used caliper is ordered and on its way I actually found a working caliper in my parts stash, but it was a left side one of course. But i will be replacing that one too because of the bad lever return spring
Thank you for your reply I did the front brakes with new pads and rotors 1000kms ago, and have been using the handbrake regularly since then. Since the car is an automatic I've never really noticed that the handbrake wasn't functioning properly. I suspect that the internal adjusting mechanism is stuck and I have to find another caliper.
My 87 EA82 Sedan didn't pass inspection partly because of a poor handbrake on the right wheel. I looked into it today and the handbrake lever on the caliper would travel freely with no effect on the piston until it almost hit the cable bracket. Then the piston would move slightly. I screwed the piston in several times but with no luck. Is there a way to set the tension on the mechanism in the caliper? Seems like it has some sort of internal play that is taken up by the movement of the lever. Also both calipers wont return the lever properly when disengaging the handbrake, but the right one is slightly worse.
Hello everyone! My 87 GL has this thing i believe is some sort of regulating valve connected to the carb bowl vent (?) and intake manifold vacuum. It also has a third hose going from the underside that isn't connected to anything. So my question is what purpose it has and should the third be connected to something?
Help! Need advise can't get the trans in!
Padawan replied to Gwywnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Manual trans? If so I suppose you've aligned the clutch disk? -
Australian side corner lights EA82
Padawan replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wagonist got it all covered for me But if someone needs pics of the setup, I can help. They are also operated by this switch in the dash -
Yes They are factory installed, and I think every subie here came with them. Theyre pretty powerful too, sprays a little bit on my windshield as well -
We have them here in Europe too. 85-86 models had solid orange glass in the turn signal part of the lamp, and later models had the ones pictured above were only the raised part of the glass is orange. Pre 87 models: -
Strange hot EA82 behavior
Padawan replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My carbed -85 did also run away at idle if I was in a traffic jam in the summer heat. It would also go down if i tapped the accelerator, or pulled the pedal back. I ended up stiffening up the spring on the throttle arm, and slacken the cable a tiny bit. Now it idles fine even if the motor temp goes up. My electric fan kicks on at about 55% up the scale -
