mwbean
Everything posted by mwbean
Here is a quote from another thread: Question #1 What is the difference between Phase 1 and Phase 2 4eat transmissions ? Question # 2 What years on Legacy outbacks did they install Phase 1 and Phase 2 and or was there overlap on production years ? Question # 3 Why did Subaru install rear drives with different gear ratio's ? Thanks
Just a follow up. My daughter wants a Legacy wagon, with a AT. Also, I already have two Legacy wagons. one is a 1992 with a 2.2L engine, the other a 1997 with a 2.5. The 92 was my first and i got it for $1500 it had a great body and interior but and it drove ok but i soon realized that the guy i bougnt it from was a crook. he had put black tape over the CEL and since I was a subie newbie i did'nt know where to look until i got a manual. once it did a check i got multiple codes and ended spending over $700.00 in parts alone. I did most of the work my self and bought lots of parts from Rock auto. but now the trans it jerks when shifting from 2nd to 3rd. (see my privious posts) I drive like a old lady and don't have to drive it very much or very far but know eventually will have to have it replaced but is in california (where I work, Long story) and don't want to pay the outragious prices of repair there in the bay area. the second subie like i said is a 97 and about 9 mos ago my son was driving it and it deveoped a leak at the bottom of the radiator and he overheated it and you can probaly guess what hapened next. yea, i had to have the heads removed and machined. Cost me $ 2500.00 So, even though I still believe subare is a good car, I just don't want to get stung again. so, i'll ask again if there are any PROFESSONAL MECANICS WHO WORK ON THESE CARS EVERY DAY Who can tell me what to look out for on a 1990 -1999 subaru and how to weed out the crap from the ok that being said i know no car is going to be perfect and i willing to spend some money on it. Thank you very Much!!
Yes, I have tried car-part dot com and sent several messages to yards and as of yet got no respose. However, as I mentioned before, I went to a local yard, Pick n pull (on west coast only) and they had 1 1991 Legacy wagon but the drive train+ the rear differential was gone + it had 267K on it :-\ but the next one was a 1990 Legacy sedan with only 134K on it and it had a rear end of 3.900:banana: so I'm gonna try to remove tomorrow. if anyone has any quick down and dirty techniques on quick removal of a soob tranny I'm all ears. thanks to all.
Ok everyone, After reading several posts here and many others on other websites and forums I think I have I have found the solution to my dilemma. I have a 1992 Legacy Wagon and am trying to find a compatible one from a donor car in a wrecking yard. When I got to the wrecking yard I found several Legacy's there. One was a 1991 Wagon but it had 267K on it so I wasn't so keen on it so I didn't write it down but the other one was a 1991 with a vin # of JF2BC67C3MH601589. The Transmission code on the same Vehicle is TZ102ZJ1AA. The code on my vehicle is TZ102ZA2AA. According to the information below, it would seem that both would be compatible, excluding the differential component of the equation which I will address in another Thread. " some magic to read your transmission id." 1234567890 <-- place in TIN (transmission identification number) tz102zj3aa <-- my AT ty752vj1aa <-- my 5 speed MT 1: t=transmission 2: A=2wd AT, M=2wd MT, Z=Full Time 4wd AT, Y=Full Time 4wd MT 3&4: distance between gears 5: 2=series code 6: A=2wd 4at, R=2wd 5f(75 distance between gear), V=full time 4wds/R(center diff & viscuss type) Z=full time 4wdd/R(Multi Plate Type) 7: A=2200cc EMPI, J=2200cc TURBO 8: 1=1990, 2=1991, 3=1993, 4=1994, 5=1995, 6=1996 9&0: no meaning This was posted on this website: http://legacycentral.org/library/transmission/intro.htm
The refrence was made that if you change your tb at 100K your ok, but that unless your mechanic is a idiot or is greedy and charges you for parts they did'nt change. I had a conversations with a customer who had their belt done and one of the new idler failed about 5k into the belt changed and trashed the engine. Lesson learned don't buy cheap parts!!
Nipper, I agree with you 100% in my experience most transmission shops are unethical almost always their pat responce is "you need a new transmission and oh by the way you can finance it for 25% intrest. the story on this car is I bought it last november and it looked ok at first glace but the jerk put black tape over the check engine light and being a noob to subaru didn't relaze it untill i bougth it had multiple codes on the cumputer. I changed the vaccume sensor and o2 sensor and that seemed to clear most of the real codes and nusance codes. when I checked the tranny fluid it was over-sevices by two quarts and based on the condition of the rest of the car I drained all the fluid out and put in new dextron III and some lucas trans fluid treatment. the real complaint i have is when in drive it shifts about 19mph from 2nd to 3rd if i continue to accelerate the engine reves up to about 2000 rpm and it finally goes into third. however, if I manually put in second and when it gets to about 22 mph i manuall shift it into 3rd and let off the gas for a second it shifts smoothly and shifts normally. this only happens on the upshift from 2nd and third. if i happen to forget to do the mallual shift, and it does the rev up roune for multiple times i get a cel code # 13. I was told that possibly doing a brake band adustment would help but neither transmission shops thought that would help. hope that helps.
sorry about the lack of info my bad. what i need is for a 1992 Legacy AWD 4speed automatic non-turbo 2.2L engine the car has 218k miles no maintence history bfr i bought in in nov 2011 dumped all the trans oil out of the pan but did't smell burnt or black etc did have a slight shimmering of brass but when i let it settle out for a few days did have a few small shavings in the bottom of the pan. the guy at the trans shop I took it too said maybe a bad planetary gear. bit it only shifts early between the 2-3 upshift.
Was having trouble with my tranny shifting beween 2nd and 3rd took it to a transmission shop and now they are telling me the tranny is shot:banghead: found brass shavings in it. now facing a rebuild or find a good used one. Is it worth fixing. I just bought in November and paid 1,500 for it and put abut $300 in it doing tune up, flushing engine, etc. the wierd thing is, the tranny fliud did't smell burnt but it was overservced by two quarts. since i didn't know the maintetce history on it i went ahead and drained the tranny and changed the fluid and found a few brass particles but noting to get all worked up about. I looked up on this forum and was told that the hesitation shift betweeen 2nd and third was probably a brake band adjustment. So, it this a Thanks everyone in advance for your input and advice!!
this one looks my lysle vaccume gage
according to my subaru chilton repair manual 1985-96 sedans/wagons (64302) it says "if any of the conditions are detected the adjusting screw can be moved 1/4 turn in either direction. Turn 1/4 turn clockwise if the transaxel -Jolts when shfting from 1st to 2nd -engine speed abruptly rises from 2nd to 3rd (my Problem) - or, shift delays in kickdown from 3rd to 2nd turn adjusting nut 1/4 turn counter clockwise if - car slips from 1st to 2nd or - there is a braking action at shift from 2nd to third. I know this a little repetive but it calrifys how much to turn the adjusting screw
