dballs
About dballs
- Birthday 09/20/1983
Location
Western Ny
Occupation
Work
Vehicles
I Love My Subaru
dballs's Achievements
Advanced Member (3/11)
0
I had a 96 2.2 and ran it from 120,000 to 318,000 miles, It was an awesome car. This make model and year happens to be exempt from state emissions OBDII inspection if they plug it in at inspection time in your state. The computer completely clears its self when you shut the key off every time so the Monitors are never "Ready". Just something to keep in mind when you have a light on at inspection time, just clear it and pull it in the shop.
Nick B- I am definitely going to change the wires, they look like aftermarket with mismatched cylinder numbers on them. Fairtax- I will check the vacuum and intake this weekend. I will take a look at the timing belt alignment but im certain its good especially after what I found last night. I believe I have a Ho2s, thats what it says on the hood emissions sticker and it is a 4 wire unit. I dont have time to change the oil to synthetic until at least the weekend so I decided to throw one of those bottles of "oil treatment" that are the consistancy of honey in. I figured for $2.50 why not try, I also filled up with 93 instead of 87 and After about 20 mins of drive time the problem was 90% gone. Accelerates very strong with a slight hesitation in the midrange. I pulled a local hill at 80+ no problem, before I would be lucky to make it past 45 up the same hill. Fuel trim reading about negative 25 now. New question: On my scan tool, for the oxygen sensor, should I be looking at the reading from the Oxygen Sensor bank 1 (Reading 2-5v) or the "equivelance ratio (lambda)" Which is reading 0.8 - 1.0 Thx for all the help and replies
Now that you mention it, it got a lot worse after I changed the oil last. Had semi synthetic in and went with conventional. My last Subaru had a similar problem. Would run like DeaTh unless I ran full synthetic... It had sticking valves too. I'll also change back to full syn oil and see what happens
I am trying to diagnose a misfire/bogging/backfire problem with my 03 Legacy GT 2.5 with 125,000 miles. It runs better when cold but not perfect but when it gets warmed up the condition gets real bad. It has trouble climbing hills and accelerating, it backfires, pops, shakes and runs horrible. Plugs are only 10,000 miles old and were gapped to spec, wires look to be in good condition, fuel filter is 3000 miles old. valves were adjusted 10,000 miles ago along with new head gaskets, timing belt and all that good stuff. If I run 93 octane the condition gets better but is not gone completely. My scan tool shows the following on a long drive: SHRTFT1=0.8 LONGFT1=0.0 SHRTFT3= (-28.1) LONGFT3= (-28.1) Front oxygen sensor is reading 2-5 volts, fluctuating but averaging about 4v Had a flashing check engine light once, shut car off and restarted and it never came back. Showed misfire on cyl3. After that No codes ever returned. If i feather the throttle VERY lightly it will drive ok but anymore than 5-10% it runs bad. I tried unplugging the front o2 sensor and running it and it had no change. There is no exhaust leaks, no vacuum leaks. Stumped and do not want to start throwing unnecessary parts at it unless I run out of options. According to what I have read, it is running rich or the computer thinks it is and it could be, coil pack, front o2 sensor, stuck open injector, bad wires, bad fuel pressure regulator. The fact that it runs a little better cold makes me think o2 sensor or coil. Any thoughts???
