About Montana Derek
- Birthday 09/27/1974
Location
Billings
Occupation
Insurance Adjuster
Vehicles
I Love My Subaru
Montana Derek's Achievements
Member (2/11)
0
87 GL wagon turbo - Therm housing bolts
Montana Derek replied to robertwheeler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, here is a picture of my current situation. Will that crack above the stud cause coolant to leak out? Is there a sealer or epoxy I can use to coat the crack no nothing leaks out? GD, if you read this, what size tap should I use to drill this out? [/img] -
I know this is an old tread, but after researching archived treads, this one appears to address what I'm currently dealing with. My engine is an EA81 and the top part of the lower thermostat bolt snapped off. I was able to slip off the the housing. I wish I could weld a nut to the remaining part of the stuck stud, but I don't have access to a welder. To make matters worse, I used a chisel and a hammer to try to cut a notch on the top part of the stud (in order to use a flat head to unscrew). Well, the chisel slipped off and slammed the block the housing bolts to, and now I see a crack. I will take a photo and upload. I need advice. I think my easiest option is to use a dremmel, and cut off the portion of the stud sticking out and re-tap. What do you think? I really like this little brat and the engine runs so good. I don't want to screw anything up any worse. There's an independent subaru shop here in Billings, and I'm thinking of just having them help me out. -
Thanks for the info. I now realize you have to type in the part number and can't use the vehicle year and model as most online parts vendors for genuine subaru parts don't have drop down options for an 82 brat. I can't stand the local subaru dealership but I bit the bullet and stopped by there today and ordered the thermostat and gasket. $24.20 was the total. He had the screen turned around and it showed their cost of $12 and change. Whatever.....
Great feedback regarding paintscratch.com!! I was one click away from ordering a can of spray paint from them. I began to waver when it said the paint for my year of vehicle was a two stage. I started seeing dollar signs and backed off. Its good to know that they are good to work with and put out a good product. Thanks again for the feedback... Red92, I like you comments about finding a color that is easily available. It would definitely be convenient to have a color that matches 100% with gloss white Rustoleum since I seem to always have at least 3 cans in my garage at all times...lol. We have a local store here in Billings which is called Big R Shiptons. It's a farm/implement/hardware/sporting goods/western wear/everything store. I was looking at their farm machinery paint and debated on buying some of that stuff...that stuff holds up pretty well and with the temperature extremes here in Montana, it's definitely an idea...
Has anyone sourced a good, trustworthy website to purchase Subaru OEM color spray paint? My local O'Reilly's doesn't carry any subaru colors...they have a few Toyota whites which are close. Has anyone used any other shades of whites that are close to Subaru Porcelain white (82 Brat)? Right now, my front left fender is Rusteleum flat white and it looks terrible.
Sorry for the poor quality on the pictures. As you can see below the rust on the left wheel well is much worse. I want to know what your opinion is to the severity of the rust? How should I fix it? The shock towers seem ok but I have no experience with rust. I tried to take an angle grinder and grind away all the loose stuff and then I put some POR 15 on it but I obviously didn't do a thorough job. Should I cut out more and have someone weld in some new metal? Should I try to have someone cut a well from a parts Brat so I can have that welded in? The exterior is clean which is weird. The right wheel well is not as bad. Any feedback you can provide will help immensely. [/img] Left wheel well [/img] Left inside view [/img] Rust on right wheel well [/img] Right inside view
I recently purchased the grill below from ebay. The guy I bought it from purchased it from someone on ebay who had it listed as a front grill for an 1983 Brat. The guy then re-listed on ebay as a grill for a 1982 brat. Stupid me, I should have looked at the photo more carefully before buying because this grill does NOT fit my 1982 Brat DL. If I would have looked at the ends, I would have noticed they are rounded. I need to re-list this item on ebay but I want to make sure I identify the year correctly as I don't want yet another person buying this thing only to realize is doesn't fit! This thing is brand new and has never been used. The emblem is still in it's original packaging. Is this thing maybe for a 1980/81 round headlight set-up. Any help or advice you can send my way would be much appreciated. [/img] [/img]
Hey Moosen, so you're orginally from Portland, OR and now living in Montana? Same here...
New Fenders & Tail Gates for 82 -Brats/Hatch/Wagons
Montana Derek replied to 1111giles's topic in Products for your Subaru
Nice work! What year is your MV1800 (Brat)? I would guess 1982 by the headlights but it looks newer. Very nice! -
I have owned four EA81 brats in my lifetime and I have never seen so many used brats for sale as I have seen these past two months...am I way off my perception?
A style pushbar vs. front end protector
Montana Derek replied to Montana Derek's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The guy said he would take $45 for it. I decided to pass on it because it was dented up and I ended up buying the A style pushbar. Yeah, I agree...anything we are able to mount on these bumpers will not do much if you hit a deer or antelope at full speed.
