Everything posted by Demon Brat
1979 Subaru Brat Part-Out
Wondering about the brake master cylinder. I just need one of the plastic brake reservoirs on the top. My son's has a crack and is leaking. I would take just the brake fluid tank, but whatever works for you. Thanks, Demon Brat Shawn
Best Rust Remover
I bought the three items, cleaner, rust converter and paint. We are on our second Iowa Winter and everything looks pretty good still.
Best Rust Remover
It can take some time but we had good luck with KBS Rust Coatings. Used it on a lot of my son's brat parts. So far, so good.
1st Gen Brat in Forza Horizon 2
My son got an Xbox One for Christmas. He got the Brat in Forza and has it painted like his. The roll bar is black on the game and his is white but other than that, almost exactly the same. It is way cool. He upgraded the motor from the stock 69hp to 220hp. With all the upgrades it will run about 120mph, handles like a dream and stops on a dime. Even the interior is spot on. At least now he can tear up the Xbox Brat instead of his own.
Voltage regulator 79 brat
I just did the same thing. Replaced the alternator, distributor and voltage regulator. Started it up and it ran like a champ....then smoke started coming out of the back side of the VR. I shut the truck off, cussed a little and checked everything again. Everything seemed fine. Started it up again and thought to myself, screw it, if it is smoking it is probably toast anyway. After a short time it quit smoking, none of the wires from the battery, alternator, VR or distributor were hot and everything seemed to be operating correctly. The back off the VR where it screws to the fender is a little warm but that is all. Inside the VR is an insulated resistor of some type that may just smoke the first time it is energized...I don't know. All I can say is it has been a week and everything is running perfect...knock on wood. I will let you know if it starts on fire or blows up, but as of now, all is good and no more smoke.
What jets you using? 1979 EA71 with weber, Also-timing issues
Replace the primary Idle jet with a 60 and the secondary with a 55. I had 50s in both. Idle mixture screw is now screwed out 1.75 turns. The idle speed screw is in about a turn, idle so much better, cleaner exhaust, no hesitation during quick acceleration, idles like a dream. Never thought different jets could make that much different.
Time for a new Distributor...need advise!
Got the new one and it was identical to the one I removed. That was a nice surprise. Put it in, set the timing and it never ran so smooth. Fixed the jumpy tachometer, smoothed out the idle. All is good for now. I found it by searching (Cardone 31-633) on Amazon. Was $97 with no core charge. So now I have the old one if anyone knows where a go distributor rebuild shop is.
upgraded headlight wiring
It is simple. You unplug all four connectors from the back of the headlights. I left them and taped them all off EXCEPT the one next to the battery. This connector is plugged into the passenger side outside headlight. It has three wires going into it. One hot for DIM, one hot for Bright and a ground. The new kit has a connector that plugs right into that headlight connector. Then you plug the other four connectors into the appropriate headlights. Find a good ground for each headlight. Connect the kit's hot wire to the battery and your done. A few zippy ties and you a sporting super bright headlights. Here is how it works. Before, when you turned your lights on the power had to run through all the factory wiring, switches and fuses to power up the headlights. With age, the wiring gets bad and you lose voltage. I had about 9 volts with the car off and barely 11 with it running. All this resistance made the bottom fuse very hot and it even melted the fuse block prior to us owning it. Now, when you turn your lights on, the power coming from the factory wiring (remember that one headlight connector you hooked up to the kit), turns on the relay that connects new wiring straight from the battery to your headlights. Thus, you get 13+ volts with the car running. it deceases the load on the factory wiring so the bottom fuse stays cool. The kits gives you easy instructions like below.
Typical problem. 1979 Brat with weak and dim headlights. Also experienced the super hot lights fuse. The fuse block was melted and we would blow fuses. Converted that to a newer spade type fuse and it quit blowing but still got hot. I measured the voltage at the headlights before doing anything. I had 9.4 to dims and 10.4 to brights with car off. With car running the voltage would jump to 11.2 and 12. At the battery I would have 12.4 off and around 14 running. My son and I bought the plug and play rewire kit with relays and wired everything up today. Now I have 13-14 volts at the dim and brights when running. This was really easy and we did not have to damage, cut, splice or remove any of the original wiring. Plus, my light fuse is now fine. It does not even get warm anymore. This is just an FYI post if anyone else is having problems like this, it was easy and seems to have cured my hot fuse and dim light problem. We bought this from eBay and it works great. http://pages.ebay.com/motors/link/?nav=item.view&id=331214602226&alt=web Have a great day.
I was able to order a Re-built Cardone. (Cardone 31-633) The whole California thing sounds about right. It came from California and I have the original California license plate. I'll let everyone know when it gets here and maybe my old one will be available as long as the new works fine. Thanks, Shawn
I have about 1/2 turn past contact on the Idle speed screw and about 3.5 turns on the idle mixture screw.
If I knew of a place in Iowa I might. Hoping to pull this one and install new one so the truck is not out of commission for too long. Maybe I'll have the old one rebuilt and then sell it or keep it as a spare?
Just completely rebuilt my son's BRAT motor. It is a 1979 Subaru BRAT EA71. It has the top starter. I think someone has upgraded the distributor because it is electronic ignition. The car was running smooth and then the tach started jumping around. I couldn't get it to idle smooth and it started dying. My USMB research indicated the distributor might be going bad. So I opened up the distributor and wiggled the rotor. Lots of side to side play. Pulled the distributor out today and found out there is a plastic washer/spacer/thing in the distributor that has(had) three ball bearing in it to allow the inside plates to rotate when the vacuum advance was activated. It was busted up and part of it was lying in the bottom of the distributor. I pulled the rest the pieces out, cleaned everything up, removed the cam gear (it was pinned in, not pressed on) greased everything and put it back together. I re-installed it with out that piece and it runs fine, no more jumpy tach, but I know it is not a permanent fix. I want to get a new distributor and below is what the motor currently is using. Part# 420852000 D4H6-01 It also has the number 812 stamped on it but not sure what it refers too. Rockauto has the part number D4H601 but it is for a 1980 Brat. Could someone just put a newer distributor in it? Think the one will work? A-1 CARDONE Part # 31633 More Info {#420857302, D4H601, D4H901, D4H902} Reman. Distributor (Electronic) $93.79 Someone who can shed some light, it would be greatly appreciated. I just want to make sure I order the right one. What distributor do I have and where do i get a new (without dropping big bucks!!) Thanks, Shawn
So my primary and secondary idle jets are 50. I have the timing set perfect at 8 degrees BTDC. I have to back out the idle mixture screw 3.5 turns to get a smooth idle. Do I go with a 55 or 60 jet to get my idle mixture turns down to 1 or 2 turns?
Hoping to pull the jets this weekend and see what size. Can't get the kid to leave it at home long enough to check. I will post after I look at it.
Yep, it has an electric choke. Here is what the stamp on the base cof the carb says... 32 36 DGAV33B1 Got the timing resolved. Had to cap off the vaccum on the PVC and Distributor. Dialed the carb in the best I could and hit 8 degrees perfect., It is running smooth now. Still need the idle mixture screwed out too far. Thanks.
weber jetting
What about an Iowa Guy with an elevation of 761 feet driving a 1979 Brat with a EA71. Idle is not smooth and I have to turn the idle adjustment screw out like 3.5 times before it sounds good.
Just finished rebuilding my son's 1979 BRAT with a EA71. We put a Weber 32/36 DGAV 33B1 on it and want to make sure we put the right jets in it. We have not changed anything yet...slapped it on right out of the box. Right now we have to turn the idle mixture screw out 3.5 turns to get it to idle smooth. Seemed to be running rich. Research says I need bigger jets. You guys could save me some time and money if I could find out what jets you guys are using in your weber. Details...Standard bore, 1979 Subaru Brat EA71, electric choke. I have both valve covers t-together and running into the breather. The PVC valve in the intake also runs to the breather. (hope this is ok??) AIS is gone, EGR still hooked up. Having issues getting the timing right...runs and sounds best about 20 degrees BTDC, Help me out knowledgeable ones.... Thanks, Shawn and Michael
Check these out...new head gaskets.
I ordered these because they are exactly like the ones I took off my son's 1979 Brat (engine stamp 12/78). When I received them I was excited because they appeared perfect, then I looked at the back and they are 80% metal. Does anyone have experience with these or this type pf head gasket? They look like they are quality gaskets, I just wonder how they will seal since they are mostly metal on the one side. Your thoughts and expertise will be greatly appreciation. I guess I'm nervous and want to make sure I only have to do this once. This side looks fairly normal. This side has mostly metal. Do I just put them on with NO sealant and follow the torque specifications? Thanks, Shawn AKA Demon Brat
WOW...$49.95 each for a 1979 EA71 (BRAT) head gasket
OK, I located a set that are Sanwa Gaskets from Japan. Part number BC640. They are identical to the ones that were removed. The Sanwa catalog calls for a BC640 for a EA71 that was manufactured from 1975 - April of 1979. After April 1979 the part is BG770. My motor has a 12/78 stamp so that explains the older style gasket. Got them for $20 each. They are a fiber/steel/fiber gasket. Any recommendations on weather to use any gasket sealant or not. I do not believe they will be sticky, they don't appear to have a film to peal off before applying them.
Does anyone have a Subaru Part number? 1979 Subaru Brat. EA71, Motor stamped 12/78
Trying to do everything right but $49.95 each for a Subaru head gasket. I called my closest Subaru dealer and he said, "wow, i can still get your head gasket and the are $49.95...each." Does that seem a little steep? If that is what it will take to keep this beast running trouble free for another 35 years then I'll do it. but WOW. My gasket set came with head gaskets but they are not exactly like the ones I took off. I need this one. But my gasket set came with this one. Notice the difference in the outside water jacket holes. Any advise? Shawn
Need a re-circulation pipe for 1979 EA71
djcommie, That would be great. My EGR valve is good so I would just need the pipe. I'll send you a message.
You guys are bad influences...engine rebuild.
Good news from the machine shop.. Head were pressure tested and everything looked good. Still installing some wheel seals and stuff and waiting on more news from the machine shop. Project is going well, just need time and other people to get their stuff done. Searched high and low for a clutch fork boot, gonna try and modify and use a 1979 Nissan boot, looks like it will work...let's hope. If it does, I'll let everyone know. Still looking for one more steering billow, got one new but can't find another one.
That is a great question ivsarge. I am in favor of simplifying the reassembly and the cleaner look as long as it will not effect performance. Isn't it the PVC valve, the breathers on the valve covers and the air breather's job to ventilate the crackcase. I thought the AIS only dealt with exhaust gases. If I could come off the valve covers and into the air cleaner that would be a nice look and simple. Plus the PVC valve. EGR valve...I thought it helped with MPG? Thoughts Thanks
