Skylar
Everything posted by Skylar
  1. Found roger some tires ! Gonna bust rump roast today, gotta fix my cv boot still and now my Rf caliper is pissing fluid so try an fix that then trim trim trim ! I'm thinking we should be able to make it .
  2. Is there gonna be a meet up time or spot ?
  3. Well I got it all fixed but i have to live with cracks in my BRAND NEW tie rod ends lol no way of getting em out with popping them . You learn from your mistakes though, this was my first time doing Bj's or tie rods . So i shot some grease in there and loosened everything up a bit, put the tires on dropped it down and then retightened everything . Tires are straighter and not toed in but it still barely moves up and down but i think thats because of the lift . Alignment tomorrow ! thanks for the input .
  4. Ok sweet ! I'll probably just go see you because I haven't had very good luck with the les Schwabs here . I figured out my problem I think ! I have my tie rod ends tightened to far up on the thread causing the tires to toe in a lot . So tomorrow getting a pitman arm and readjusting the tie rods, loosening the Bj bolts and set it down then tighten everything to where they should be and hopefully that'll fix lol
  5. No worries lol I have 215/75/15s that are drilled for my offload tires . Which I haven't even used yet and 205/60/15s with pugs for on road . And that's lame I would not buy tires from them even if mine were bad
  6. I planned on going to get an alignment after i was done ... My alignment got kinda bad after i lifted it but my wheels are also not balanced right . ( cheap a** tire shop threw on some "sticky" type weights on and not the ones that goes on the bead of the rims ) so they came off doing doughnuts in the previoius snow we had. And the bj and tie rod ends rubber was ripped . and i dont have redrilled rims on right now. i have 15" pugs
  7. Also everytime i go back and forth i hear a " click ", it didnt do that before but i checked all my Cv's and none of the boots are torn . So i think im good there .
  8. From now on if I don't know something I'm asking on here instead of someone else .! Lol I asked one of my buddies and he said to tighten everything up while in the air ... So after I'm done doing my buddies front end on his 80 wagon back to the garage I go ! And it's not a AWD auto , 5 sp manual . And Rob I'd love to come up there but I don't even feel comfortable driving out of my driveway ! Im also running no sway bar .
  9. So i just got done doing my balljoints and tie rods ends, rotors and pads on my 88 gl and i put everything back together make sure i tightened everything down right and put new cotter pins in . It was sitting in my garage for a couple days on jacks . Dropped it down today and the tires were sitting kinda toed in like this \ / Went back & forth a couple times seemed to even out but my buddy noticed everytime i went to go forward the front end would lift up like 4 in and when I'd go to throw it in reverse and go it would drop back down . And when id go to drive it just felt like it was all over the place . Very bad wobble . My tires need to be balanced but i dont think that could've caused it . Could i have messed the camber/castor up that bad when doing the suspension ? I live like a 1/2 mile from a les schwab where i plan to go get an alignment in the morning but i almost dont even trust it to drive over there w/o messing something up, it feels that weird.. Any input would be appreciated , need to get this frickin thing done ! Thanks guys Oh and it has a 2" lift
  10. Ive had the oil pump seals for a couple weeks. Should i go OEM or Felpro for HG and what other seals do i need ? Just did the valve covers today ... I'm thinkin that if i gotta pull the motor it might be time to consider an EJ ... hmmmmm
  11. Is there any type of temporary HG sealant that i can stick along that seam ? Or is it HG time haha
  12. Just got done doing both balljoints and tie rod ends, went with MOOG parts thanks to the forum Also new rotors and pads, bled all the brakes. Doing the valve cover gaskets in the morning and getting my tires balanced and probably an alignment
  13. I believe I found the source of the coolant leak ! Passenger side head gasket . Yayy Only leaks when sitting over night or a couple of days in the garage . And stays dry when I'm driving it everyday . Small sized puddle built up over the past couple days . Guess I didn't look hard enough last time lol
  14. oh and my rear pass. cv boot at the diff took a crap on me so i gotta reboot that too .
  15. Damnit ! Lol I knew I should've waited to hear back from you or josh . I have her in the garage now, doing my Bj's and tie rods. Rotors and pads and possibly wheel bearings but I should have all that done by tomorrow or so . I'll get ahold of you .
  16. I'm still in for now.. I have a decent list of things i need to get done on my soob, hoping to get it all done by then .
  17. It's that bright red thing sitting under my diff ...
  18. Right on ! And yeah so far so good man And thanks for letting us join !
  19. Yeah that's no biggie . But yeah if you could make me a set that'd be great . Pm me with a price .
  20. Yeah I was just starting to think about that... And If you could do that for me man that would be awesome ! I don't have much experience with welding, just some oxyacetylene . So I couldn't do it myself lol And extending my radius rods isn't gonna make the tires stick out will it ? It just moves the ball joint forward not out ?
  21. Here's a crappy pic of the 215's on . Got them drilled out ..... Let's just say I got ALOT of trimming to do..... Could I go with 3" blocks in the front to get it level and not have to drop the x-members ?
  22. It was good to meet you too Scott . And thanks . Can't wait to go test em out !
  23. Thanks man ! I just went through your whole build thread. I like your rig, and the ej sounds beautiful lol
  24. Yeah I'm stoked to go wheeling as well !
