Everything posted by Skylar
How do you find Brat rear seats..
Skylar replied to Paperscale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ive got a set for sale in Tacoma wa with headrests. $150 -
5 lug parts on a EA82 whats what?
Skylar replied to Scott in Bellingham's topic in Subaru Retrofitting
Front hubs/ knuckles will work. Will have to drill out crossmember for the larger bolt on the xt6 control arm. Also swap top hats. Ea82 top hats on xt6 struts. Inner doj will have to be swapped if not a turbo loyale or turbo trans. Xt6 have 25 spline inner axle cups. NA ea82 has 23 spline. You can use EJ hubs/knuckles but will have to use ej axles. I think struts can be swapped around like using ej struts on xt6 knuckles or vice versa. -
Ea82 engine crossmember in ea81
Skylar replied to kirzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It was Gloyale. He has a thread on here somewhere with pics showing where he cut & welded some tabs to mount the 82 crossmember in an 81 -
Not the same.
Nice build so far man! Pretty sure I was this at WCSS last year. How much bigger did you have to make the holes in the crossmember for the Ej to fit ? I'm about to get started on my Ej swap in my 84 wagon
EA82 Coupe Can't Adjust Door To Shut Completely
Skylar replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What is this striker you guys speak of ? Having the same issue on my 87 RX. SO MUCH DAMN WIND NOISE ! It's killing me lol -
webercarbsdirect-Have i been burned?
Skylar replied to 87subbomber's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The truth is real webers are made in Italy, not Spain. The ones made in Spain aren't bad, in fact I think the one I've been running on my ea81 for years says made in spain. I say tune it and run it. What's the worst that's gonna happen ? -
5spd 4wd dual range swap with auto. starter issue help
Skylar replied to RunsWithMoose's topic in Subaru Retrofitting
Yep. You need to jump the NSS switch. Should be a white 6 pin connector where the 3AT shifter was. I converted my 84 wagon from a FWD 3AT to a 5 speed dual range earlier this year. -
Tips / tools for removing RX LSD?
Skylar replied to JLow03's topic in Old Gen.: 80's GL/DL/XT/Loyales...
17mm on the diff studs. I think the big nut & bolt on the hanger is like a 22mm & a 19mm or a 19 & 17 -
If you're interested in selling a few parts from it I'd be interested in the rack. Just the Main frame, I have all of the pieces for the middle of the roof. Also, I need this little trim piece on the rear passenger door. And I'm not sure if there is a interior plastic piece that goes below the rear cargo area windows but I'd need those too. Neither of my 78s had them.
Looks like Robs old hatchback ( Turbone ) From what I know it just sits at Ricks ( General disorder ) shop and he let's production company's use it for movie props every now and again..
Dude nice score! If you have no plans for the lift, and want to make some money back, I'd be interested in it. I'll shoot ya a pm.
