PadreScout
Everything posted by PadreScout
Did your motor just die too? Haha, mines also about shot and I'm currently debating EA82 replacement versus doing a Ej22 swap. Obviously it's a conspiracy. Engines go on sale- ours die..... EDIT: In all seriousness though, I am actually getting very frustrated with my GLs engine. Could you guys recommend a good outfit to do an engine swap or replacement? I ask because am in an apartment these days and swapping it myself would be an issue.
WUH?!? Somebody makes a spring that will by design fit my GL?! SHUT UP AND TAKE MY MONEY! No seriously, I still don't have my freaking suspension sorted out and I am very interested. Have a link?
Welp, I got a 94 Nissan Maxima alternator, built by duralast - part # 14661 at autozone. It doesnt fit, there's some bushing in the mount that wont fit into mah car. I would consider filing it to fit except the plug is wrong as well and well, this is looking bleak. pic of the offending part: in summery- the 94 year model alternator seems to be a no go.
I'm back! I have been slowly whittling away at my new/old GL and have hit a bit of a wall, I replaced to the temp sensor and IACV because it idled MUCH too low when cold. I have created an interesting problem in doing so. The situation: When cold, the car idles low, around 500-700 RPM, wont start/ stay running without me keeping a toe on the gas pedal to raise the revs. Once warm the car idles high. Like... 1500-2000 RPM high. Now, by my reconning the car is doing exactly the opposite of what it should be doing. Do you guys have any idea what would cause this? I checked the search, but saw nothing that fits my circumstances. Thanks!
Well, I set to doing bearings to fix the drumming my GL was making (yeah, just getting around to it. I can procrastinate) . pulled the wheel off to find this: Yeah, that is not a cotter pin and the nut was on hand tight. That explains SO MUCH! I pulled the corner apart enough to know I need new ... everything , so I ordered new wheel end and axle stub and put it all back together only tighter. I'll fix this damn car yet.
wow, mine is doing the exact same thing- must be an '88 thing or something. I cleaned my MAF and throttle body and that helped some as well, so you might want to clean those if you havent already- didn't outright fix the problem, but it did help somewhat for me... maybe that plus this air thing theyre talkingabout will fix that right up.
Howdy Ya'll! SoobNoob Here ;-P
PadreScout replied to usafmvp01's topic in Meet n' Greet. Your USMB Welcome Center
You are awesome! I just bought a '88 GL Wagon with SPFI and 4wd as well! Coencidently you want to do mor or less the same stuff to yours that I do mine- this makes us some sort of spiritual twins. Good luck with your project and welcome! -
I changed the oil in my GL today! Also I decided the GL will be hereafter referred to as "The Rock". I also changed the gas struts on the rear hatch; this provided two benefits: one it no longer attempts to knock me unconscious while I root around in the back-end, and two, it makes that great deloren door opening "imma gas strut extending" hiss sound. I love that sound. Next up I'm going to hunt down a vacuum leak that has my engine idling all wonky.
Is that a spring for the front or rear? Also these spring dimensions being thrown around are for the 4WD Ea82, yeah? Sorry, but between 2WD/4WD , front or rear ... honda, tempo, intrepid - I've become quite lost and I happen to be in the market for springs on all corners I am attempting to get this cleared up (plan B is taking the springs off and measuring them, but what a hassle.)
drumming on the highway
PadreScout replied to PadreScout's topic in Old Gen.: 80's GL/DL/XT/Loyales...
read that, very nice info, but it's a bit confusing in places. for instance, it leaves a bit of doubt in my mind as to which accord springs fit which GL (I think its front accord to rear GL ... but in the 2WD or 4WD?) and I have no idea at all about which Tempo springs fit a 4WD GL at all. EDIT: Discovered to PO is a bit of a liar, the rear berarings, which he claims to have had redone are REALLY gone and the freaking half inch of play in the wheel is the noise I've been hearing. At least, I hope that's all the noise. -
I'm making a list of things to fix/replace that'll hopefully fix the sound up (and generally improve the subby) I'm going to have the exhaust replaced next week. I have ordered new shocks and I am currently trying to find springs that fit, in another thread they said the springs from an 89 Honda Accord with AC work, is that front and rear? As for the possible axel gubbery- I have a buddy that used to do front end work for a living and I have him coming over to poke at that. So I'll get this bad boy all fixed up. -
Yes, there is some slight wheel shake as well- nothing violent or anything, just that kind of "i ran over a joint in the pavement" kind of ... nudge, that goes with the tempo of the drumming. It tracks straight as an arrow though. Shocks, yes the shocks are all completely worn out- I have some KYB Excel G shocks ordered. I cannot find the model number to put gas adjusts on all corners , so the Gs should work- they'll sure be better than the blown out things on the machine currently. Now that it is brought to my attention: Yeah, that axel does look a little wierd. I'm going to run some errands and let it warm up, this afternoon I'll take better pictures and post those. -
I wasn't sure what to take pictures of, so I took a couple under the hood, and some under the car - hopefully these help. gallery About the car, it's an 88, has about 186,000 miles on it. It started doing the drumming at like 35 miles an hour last time, so it'll do it at low speed. -
bridgestone insignia se 200 in 175/70/13s. They look brand new. Interesting thing- I took my car for an oil change today- didn't do it. I then took my brother for a ride and it started drumming again, this time from passenger rear. I think it's something wacky with the suspension or something. -
... maybe. It's glorious though! -
Hey guys! I bought a Subaru and am very happy- well, I was very happy until I had to leave it at a gas station an hour from my house. Why would I do that? Well, at highway speeds 60-65 and faster, it would make an intermittent drumming sound, like LOUD, I didn't worry too much about it at first, but it went from every now and then to most all the time and the tempo would change periodically- I finally decided it'd be best to park it and trailer it back. I'm thinking wheel bearings, but those usually squeal or something, this is very bassy like.... drumming, the steering wheel would kind of tremble slightly but the whole car would rattle from it. The sounds coming from passenger side front somewhere - bearings sound about right?
General Subaru noob dumb questions
I fear I may have recieved too much good advice, now I am torn. I have decided I will go and look at the GL anyway, but unless it is in very very good shape- I will pass and look for a Legacy of some sort. Are the early 90s the ones to have, or is anything nearer to 2000 worth a look? I'm basically looking Wagon, 4WD for occasional wintertime or off-roading hijinks. I understand the legacies are all-time AWD, which would be nice, but frankly my area is very very flat, and it seldom snows or ices up (or rains) so really, the FWD of the GL would be fine except for when I want to go trucking around a nice dirt trail. Anyhoo, hows that sound to you guys? -
Yeah, that's the thing, I drove a bunch of old ORVs in highschool so I am not intimidated at all by having to do some work - but my favorite rig (the Scout) was like ... super super super super simple. This GL could be on the cusp of "oh poop, electronic stuff they haven't made in 15 years are breaking". This happens to my BMW K75 all the time and it's a real hassle. I /want/ to go GL, but I might just listen to saner opinions this time and go Legacy. I'll think on this more..... thank you for all the advice!! -
Hmm, the information on a Legacy is interesting, I googled the car and I'm not sure it speaks to me. I may be screwing up here, but my impulse is to go with the GL simply because I like it better, despite being a mechanically inferior machine. My spidey-sense tells me this decision could very well come back to bite me in the butt. -
I apologize, it is the 5 speed manual with a 2 range transfer case. That's about the only thing I knew I wanted on the car. -
First Off thank you very much for the information, I find I am below the cusp of knowledge where I know what questions to ask so I can find what I need easily, so I really appreciate you taking the time to help me get there. Second, this DR tranny, I assume that is the transmission a 88 GL comes with, so I can simplely drop in this EJ22 and itll bolt right up? How does it sit engine mount wise cause frankly the ability to drop in a more modern powerplant is exciting to me. -
Hi there! As I mentioned in my intro I am in the market for a nice GL. I've been kind of researching a bit and learned a lot, but also been confused by a lot of stuff that evidently I should know, but do not. here is a bit of a running list, if you guys could help I'd sure appreciate it. EA81/EA82, it's engine codes, yeah? I know these somehow relate to the year model but I don't understand how. The wikipedia shows some overlap in the 80s between the two.... which is the motor to have and why? Is motor code all that this describes? Tires: Stock tire size on these Loyales is a 13 inch of some sort- but most tires I see on the pictures look to be 15s of some sort.... these are all lifted vehicles or the body is modified to fit larger rubber? roof racks and bull bars and such: I love them, according to that "check out the cool old Subaru!" thread the Subarus even seemed to come with the things at some point (the one I want to buy doesn't, hence my interest in acquiring one). Where are you guys getting these things? Custom built or are there vendors out there that cater to the old Subaru market? Same question regarded roof racks. The 4 wheel drive, I am looking at a car to buy specifically (looking good so far, might have it Friday!) and it doesn't have that orange 4 wheel drive button on the shift knob, so .. how do you engage the 4 wheel fun? Evidently the RX trim had all-time 4 wheel, I assume this 88 GL doesn't so how does that work? Returning to all this lifting/big tire fun, how do the little 1.8 litres handle the bigger tires? I have a mild fantasy of eventually dropping in a little diesel of some sort, in the time before then I kind of want to go up in tire size but am afraid I will really guy the acceleration doing it. How is you guys experience with that?
