sasquatch
Location
Vancouver
sasquatch's Achievements
USMB is life! (4/11)
10
so...........the problem is gone. Yesterday after pulling the codes and getting the purge solenoid and injector #4 I just made the connections were on properly. Afterward it was still running very rough and this morning on my way to work it was bad. Getting in it after work? She ran great. I am relieved that this would seem to indicate the problem isn't too serious. Sticky injector? What do you think?
Thank you for being the only person to reply. The plug wires are only a couple weeks old and as far as a hotter plug, I do have the recommended plugs in the vehicle, but what plugs do you recommend? Which are "hotter"? I swear after all the tinkering yesterday the car is running a little better though I don't know why and I'm not convinced that one cylinder isn't fubar'd. Until I see white smoke tho' I'm going to keep trying. Does cam sensor failure cause similar symptoms?
I got home today, pulled the plugs, gaped them, shined up the contact points and put them back in...it didn't work this time. The plugs actually look normal....hmph. I had heard that the cam sensor can cause a similar symptom so I took it and the crank sensor out, removed the grime on them and reinstalled.....nada. The car is still running rough. Ideas? I tried to pull the OBDI codes and couldn't figure out which plugs to connect/disconnect. I've done it before but it has been quite awhile....I've never found OBD1 codes all that helpful anyway.
I have a '90 Legacy Wgn with 240K. About three months ago it started shaking at idle and had a VERY rough spot around 40mph. It felt like the car was missing, not a fuel thing. I just happened to have the right spark plugs on my shelf, put them in and it worked just fine. Last month the symptoms returned. I put in a new fuel filter and plug wires but that didn't do the trick. I then pulled all the plugs, shined them up with sandpaper, reinstalled, and the car was back to running right. This weekend we took this car on a 400 mile trip over White Pass loaded with camping gear. The car was running hot at the top of the pass (I suspect bad themostat as it was aftermarket). When we got to the camp spot, I took out the thermostat and took the car for a ride and the motor no longer got hot but then the rough running was back. I pulled the plugs and tried to clean them again, but I didn't have sandpaper and had to use the green part of a kitchen sponge. :dead:The car is still running rough. It did make it all the way back home though (I LOVE this old car). There is no doubt in my mind that I have weak compression in at least one cyl but I haven't checked yet. The car is not smoking nor is there any white residue in the oil. When I get home today I'm going to see if I can borrow a compression tester from the neighbor and try the sandpaper trick and regap the plugs. What the heck do y'all think might be wrong??
A couple months ago my wife came home complaining that our 90 Legacy was running rough. The plugs were kind of fouled and so I swapped them out and voila, running well again. Two days ago after I'd gotten some gas about 5 miles later it started running like it was missing. It develops a bad shake at about 45mph that goes away if you let off of accelerator. In park other then a bit of a rough sound at about 2k it revs just fine, it is only when it is driving. Thinking it was spark related, I pulled the plugs, shined up the contact points, put new wires on. Then to make sure there wasn't a fuel issue I put in some fuel line antifreeze and changed the fuel filter. I drove it about 15 miles and no change. HELP
I think I have to buy it...
sasquatch replied to sasquatch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump -
I just drove the car around today and took it to a softball game and the car behaved just fine and threw now codes...I haven't messed with the plugs though to try and pull the codes for myself. It pulls strong right up to the redline in all the gears, no creaks or groans in the chassis, newish struts/clutch/tires. 4wd engages and disengages w/o any ominous sounds. -
Looks like it also threw a code 11 crank angle sensor..what am I in for there. I have to talk to the previous owner but she said the shop she took it to "disabled" the CEL. How do you suppose they did that? -
so, the car was brought over today...the interior is PERFECT...no rips, cracks, NADA. No dents to the body bigger then a fingernail. The headlights aren't even cloudy. I drove it, motor and tranny seem fine (I'll do a compression test tomorrow), 4wd engaged and seemed to operate prefectly. The previous owner had the error codes pulled which they listed as 34 EGR & 24 Idle air bypass problem. For $800 even though I'm currently unemployed I'm not sure I can pass this up. What should my next steps be?
