5
jmoss5723 last won the day on October 19 2016
jmoss5723 had the most liked content!
Gender
Male
Location
Pittsburgh, PA
Occupation
Headhunter
Vehicles
'04 Forester, '02 Outback, '84 Brat, '83 GL Wagon
Recent Profile Visitors
2123 profile views
jmoss5723's Achievements
Subaru Nut (7/11)
181
After a catastrophic chain of events set off by the failure of my A/C belt tensioner pulley on my Forester, I replaced timing belt and idlers, timing cover, A/C tensioner, accessory belts, and crank pulley. Then I reinstalled my rear sway bar, replaced a blown speaker, and fixed up my failing driver's window motor. It was a busy Sunday.
Does anyone have a clever idea on fixing my rad support? The cross bar itself is still solid, but the mounting locations for the bottom of the radiator are 100% gone. My radiator is currently resting on a bit of wiring harness and held in place by the rad hoses. Should I just weld on some new mounting tabs of some sort? (I'm a pretty crappy welder and my welder is crappy. We're a dream team!) Should I buy a new lower rad support from the JY and install it? Something else?
Timing kit went on no problem. All is well with the engine now. I do still need a new tensioner for the A/C belt, though. Some interesting bad news is that my radiator is basically just being held in by force of habit. The mounting points for the bottom of the radiator are completely rotted off the rad support. I'll have to come up with a clever solution to keep it reasonably in place.
2004 Forester XS (SOHC EJ251) Is my crank pulley shot? If so, how/why? Short story: I can hold the outer edge of the crank pulley in place, but the inner portion spins. Long Story: Today I was trying to remove my crank pulley in order to replace my timing belt. I have a chain tool similar to this one that I use to hold the pulley in place. With the outer edge of the pulley held in place, I began loosening the bolt that holds the pulley to the crankshaft. This is where the problems start. The outer portion of the pulley stays still, while the inner portion turns with the bolt. Just to double check what was happening, I pulled the driver's side timing cover and confirmed that I can turn the crankshaft while the outer edge of the pulley is held perfectly still. Longer Story: The other day My car suddenly started idling really rough while I was stopped at a light. It stalled itself out, but I got started and pulled to the side of the road. Running terribly and lacking in power BIG time. I popped the hood and saw that my A/C belt was shredded. The nut that holds the idler pulley to the bracket of the A/C belt tensioner was GONE. The belt forced the pulley into the timing cover, which cut a big hole in the cover and shredded the A/C belt. I suspect that the pulley also pushed on the timing belt and caused it to jump time which gave me the rough running and low power. I basically idled it the 2 blocks home and started to tear it down. That's when I discovered this odd behavior from the crank pulley. Any advice?
Brake pulsing never came back. I still have no idea what happened there. The car was sold a few months back to buy a minivan for my growing family. It was a bummer to have to sell it. It was probably the best subaru I've had yet. It's still rolling around though. I saw it on Sunday, a little dirty, but no worse for wear.
AH! I'm super pissed at myself now for not downloading an offline copy of the ski wagon page. You should get in touch with photobucket's customer service team and see about a free one-week trial or something. Then you can save copies of the threads and keep your $400.
- 261 replies
- 1
- Restoration
- Coupe
- (and 4 more)
