smiffy6four
About smiffy6four
- Birthday 08/06/1961
Location
Ontario
Occupation
Mechanic
Vehicles
99 Forester
smiffy6four's Achievements
Member (2/11)
0
Have you tried adding the AWD fuse? That puts the car into FWD and stops sending power through the rear driveshaft. IF the vibration is still there with the fuse in, then you know to check the front. Sometimes, it's useful to swap the front cv shafts, side to side. If the problem moves to the opposite side, then you have your answer. If it doesn't make any difference, then you may gain more life from the cv's anyway, as they are now driving on the less worn faces of the cv joints.
You'll need a universal joint for a 3/8 ratchet, and a couple of extensions. Plug gap is 0.042". Take the wires off one at a time. I always add a small smear of antisieze compound to each plug thread; this makes them easier to extract next time and prevents carbon from creeping up the threads, which can abrade the threads in the aluminum cylinder head. Take your time, don't overtighten the new plugs.
Patching rusted out panel
smiffy6four replied to J.T.R's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or just cut a strip of sheet metal, stick it on the inside and bondo over it.
