smiffy6four
Everything posted by smiffy6four
Have you tried adding the AWD fuse? That puts the car into FWD and stops sending power through the rear driveshaft. IF the vibration is still there with the fuse in, then you know to check the front. Sometimes, it's useful to swap the front cv shafts, side to side. If the problem moves to the opposite side, then you have your answer. If it doesn't make any difference, then you may gain more life from the cv's anyway, as they are now driving on the less worn faces of the cv joints.
You'll need a universal joint for a 3/8 ratchet, and a couple of extensions. Plug gap is 0.042". Take the wires off one at a time. I always add a small smear of antisieze compound to each plug thread; this makes them easier to extract next time and prevents carbon from creeping up the threads, which can abrade the threads in the aluminum cylinder head. Take your time, don't overtighten the new plugs.
Patching rusted out panel
smiffy6four replied to J.T.R's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or just cut a strip of sheet metal, stick it on the inside and bondo over it. -
This is what you need to try next. Then try the test with the AWD fuse installed. This will switch to 2WD and usually eliminates most noises associated with the rear wheel drive components. If you have four good quality axle stands and can SAFELY get all 4 wheels off the ground, have a buddy "drive" the car up on stands and listen with a stick or stethescope to the various drivetrain items.
Putting a subaru tranny in a synchro or rear mount
smiffy6four replied to nipper's topic in Subaru Transplants
yup, it can be done. I was looking at his very idea yesterday. I have an 85 VW Vanagon and a Subaru. It occured to me to marry them up. -
I would agree; having been welding cars for 25 years. I use .025 wire with argon/C02 for shielding gas. Flux core has it's place, but is best for thicker metal(i.e. not sheet metal) and outdoor work where shielding gases get blown away. Look for a decent quality welder, such as a Lincoln or a MIller. Cheaper welders often have a torch that's live all the time, which makes it easy to flash yourself. I have this baby: http://www.canadiantire.ca/AST/browse/6/Tools/WeldingSoldering/Welders/PRDOVR~0588041P/Lincoln+Electric+MIG+Pak+180+Wire+Feed+Welder.jsp?locale=en
The bearings are pre-greased, do NOT add any more grease to them. I just replaced a set on a 2000 Forester on Friday. I had the factory manual and factory tools to do the job, so that made life easy. The link bolt was very tight, as it had rusted onto the knuckle. I got it to turn once I had the nut off and put a long breaker bar on it. If you don't have a slide hammer to pull the hub off, I'd recommend using a 3 jaw puller if you have a lrge enough one. Otherwise, you can make a poor-man's puller using a length of chain placed over any two opposing wheel studs(do the nuts up all the way to avoid mashing the stud threads) and a heavy bar(such as an old half shaft from a pickup)The technique is to put the bar thru the chain and snatch it back towards you, thus shocking the chain and pulling the hub out.
