stickedy
About stickedy
  • Birthday 12/05/1979
  • Gender
    Male
  • Location
    Kronach/Bavaria/Germany
  • Vehicles
    EJ22, EA82 + E12
stickedy's Achievements
USMB is life!
USMB is life! (4/11)
10
  1. Hello! What injectors are used in the EJ201 engine? Are these Bosch or Denso? I found on ebay these: http://www.ebay.com/itm/Set-NEW-1000cc-BOSCH-Fuel-injector-E85-OK-WRX-LIBERTY-2-0-2-5-L-NA-EJ201-EJ251-/161924057720 Are these the correct types? Thanks a lot!!
  2. Hello! I have a problem with my IACV / unsteady idling after swapping my engine (from MT car to AT car), see http://www.ultimatesubaru.org/forum/topic/159399-swapping-engine-from-manual-transmission-to-automatic-transmission/ Everything is fine so far, but the engine is idling bad, alternating between about 400 and 1.400 rpm constantly. Sometimes, however, it works fine... The ECU throws me the error code 35 for the IACV. I already swapped over the IACV from the "AT" engine in an try to correct the problem, but it had the same part number and it changed nothing. I was searching the FSMs for any hint how and where to find the issue. But I didn't find any difference between AT and MT except that there should be some voltage with AT when testing it. However, I can't find any difference in the wiring diagrams. I also changed the spark plugs and the ignition wires just in case and to be sure it's not somehow related. Please, do you have an idea what this problem is caused by? I'm a bit stuck with this problem... Thanks!
  3. Hi! Sorry for replying late, I was busy the last weeks. I had successfully swapped the engine, everything is fine so far. But I have a problem with the IACV. the engine is idling bad, alternating between about 400 and 1.400 rpm constantly. Sometimes, however, it works fine... The ECU throws me the error code 35 for the IACV. I swapped over the IACV from the "AT" engine, but it had the same part number and it changed nothing. I was searching the FSMs for any hint how and where to find the issue. But I didn't find any difference between AT and MT except that there should be some voltage with AT when testing it. However, I can't find any difference in the wiring diagrams. Please, do you have an idea what this problem is caused by? I'm a bit stuck with this problem... Thanks! Edit: To answer the last question, both cars where the generation from 1989 to 1994, the donor car a 1992, the receiving one an 1994, both first gen and nearly identical (except for the AT and air suspension). No problems with any EGR or such things, both were plain EJ22 engines.
  4. Yeah, that's for sure. And learning something new The overheating car has no a/c so I have to swap that over also.
  5. I have to swap over my my engine (2.2 1st gen) from a manual transmission car to one with automatic transmission. Are there any thing I have to look at or which are problematic? Are there any fluids going out when separating the engine from the auto transmission? I have done a couple of EA82 swaps before, but I had not to deal with automatic transmissions yet. Thanks!
  6. So, I verified it: Bubbles in the coolant expansion reservoir when overheating. Tomorrow I'll swap the engines.
  7. I had the problem with a Ford Transit a couple of weeks ago that I destroyed the master cylinder seals by pushing the pedal all the way down. Result was pumping air in each time I push the pedal... Was also such a never ending story. After changing the master cylinder, everything was fine instantly.
  8. Ah, I see! That explains everything. I didn't have the information about breaching the head gasket between exhaust and coolant. So I will try to confirm the damage today (bubbles). And if so, I will exchange the whole engine. Since I have a LPG modification in my other car and I also have to swap that over (for money matters) - and the a/c - , I don't want to fool around with changing head gaskets then. I will do that with my brother, both cars besides each other, should be a quick thing It's not the first engine, I exchanged several EA82 in the past, so no problem in doing that at all. Bu you know, avoiding work is always the target
  9. I know the coolant should be sucked back when cooling down, but I'm irritated by the speed. The whole action from stopping the car to a fully refilled cooler didn't last more than 5 or 6 minutes. In this time, there can't hardly be any significant cooling down in my opinion. Or am I wrong on that point? I tested the cooler cap in my other car - the soon to be replaced one - it's working fine. That was my first idea after buying the car. Hmm... However, could it be that the cap can't hold the pressure sometimes and sometimes can? I'm not used to problems with the caps, since I didn't face any yet. Thanks for your ideas. I will test the head gaskets (compression) for sure.
  10. Yeah, he knows about it. And I also before buying it. And therefore the car was cheap, I buy it with the idea of either fixing or exchanging the engine. The rest of the car is in really good condition, so it was a good deal. But if it's an easy fix, I want to avoid exchanging the engine, since there funnier things to do during a day On Tuesday we will check compression on all cylinders and tomorrow I try testing again while idling and looking for bubbles.
  11. My new station wagon - I bought it with knowing the problem - has an overheating problem, a mysterious one somehow. It's a 1994 1st gen Legacy 2.2 without a/c and automatic transmission. I registered the car on Friday and drove about 80 km (50 miles) without problem (even idling for about 20 minutes) while it was quite hot. On Saturday it was much cooler and I drove for about 20 km (12 miles) and suddenly the temperature was quickly rising from normal to hot. I immediately pulled over and checked. There was much water coming out of the overflow of the coolant expansion reservoir. And now something mysterious happened: I picked up some coolant fluid to refill and opened the cap of the coolant expansion reservoir. It was full to the top. And suddenly the coolant was sucked back in the cooler really fast. It was like if you have a glas of Coke and trink it with a straw. This was so quick... I put in about 1.5 liter of coolant before it stops. I was then opening the cap of the cooler and there was no pressure or vacuum on it. No visible leak, nothing odd. I then start the engine again, temperature was back to normal, I switched on the heating for checking and drove home. When I nearly got home, the same happened again, the temperature of the heating dropped so there was too few fluid in it. I hadn't time for more checking since I need to get somewhere and just picked my other car. So, has anyone any idea about that? I have never seen something like that sucking back ever again nor heard about something like that. Anything is appreciated! Thanks!
  12. Ah OK. Now I got it Phase 2 was used starting with MY99? So a Forester from 1998 or early 1999 should have a Phase 1 EJ20?
  13. Hi! I have a question: I'm thinking about buying a Subaru Forester MY98 or MY99 with a broken engine and replacing it. Now I found out that the Forester uses EJ202 engines instead of EJ20E used in Legacy and Impreza. What's the difference? Can I put in an EJ20E without changing the original ECU? There are many old and cheap EJ20 Legacy out there with working engines just rusting away so that would be a perfect swap... Oh, to clarify: In Germany the Forester was offered with a 2.0 L engine (like Australia), not with 2.5 L like in USA. Thanks!
  14. Thanks! I will pull one of those actuators tomorrow and play with it. Then I will see if it's really damaged. I hope it's getting warmer... There's no frost but pretty cold just above the freezing point. Not the best weather to make something outdoors...
  15. That was my first idea: disconnect the battery and the locks work again. But it doesn't work... Same behaviour regardless of the battery connected or disconnected. That's the weird thing I don't understand... I will have a look at that switch later and I will also look for the keyless entry control unit, I read some postings on the internet that it could cause such trouble.
