Aero1
About Aero1
  • Birthday 09/11/1952
  • Location
    Hewitt NJ
  • Occupation
    Auto instructio
  • Vehicles
    94 Loyal 99Legacy
Aero1's Achievements
Newbie
Newbie (1/11)
0
  1. Hi. I have the new knock sensors, you will be able to send and receie pm's messages after 10 posts, so for now, I left a visitor message. My paypal for knock sensors is : bheinen@yahoo.com
    thanks.
    brent.
  2. The A/ F relies on a reference voltage [battery or a 5 volt reference from the PCM]. If This voltage is not very close to battery voltage, with in .2 volts or the 5 volts is off say 4.6 or lower this will be enough to set a code. The same is true for ground. If you put the black on the batt. neg run the car and probe the ground wire with the red pos. lead there should be no more then .05volts better less .02. If ground is bad this will set a code also. This sensor works on heat generator-ed by the sensor as air passes over the heated element the element cools and the resistance changes this is what the cars PCM calculates fuel demand for the engine. I hop this helps Kevin
  3. Hi I am in north Jersey also I need cams anr rockers for my 1994 Loyal wagon can you help
