About subarurx yo
- Birthday 02/20/1990
Location
olympia
Interests
subarus
Occupation
none
Vehicles
1987 RX hatch turbo awd
subarurx yo's Achievements
USMB is life! (4/11)
So I thinned my harness down for a swap its 02 or 03 wrx harness, pretty sure its 03, and somewhere I wiped out the wiring for it to be jumped into test mode to flash my ecu. Any ways who knows where those wires go, so I can wire those in? I've got the ecu pin out, just not sure what I'm searching for...
I've been Having problems with my swap, when trying to do pulls my Afr drops to 10.8 ish to 12 to 1 ish and spudders bad, I'm not running an o2 sensor for ecu either, but for about 1k after swap there was no spuddering at all. Now it randomly started missing on 1 and 4, the Afr goes totally pegged lean, but when my rpm goes above 2k the miss stops and runs like it did before, rich and Poopy.
ok so I got a code for the tgv sensor 1 low input. Im thinking that could cause possibly this issue since theres of course on sensor per pair of cylinders. It ran ok-ish before then, just limp mode of course from MAF, then runs HORRIBLE! withTGV and also a PVC code, those weren't there prior. I did a tgv delete, with the rods in it, so it "thinks" it's doing the right thing. The turning rod in the housing seemed pretty stiff to turn, so I'm gonna give it a checkin'.
Car is missing badly and I did a leak down test and all cylinders were great. cylinders 1&3 the plugs are totaly black rich, and 2&4 the ceramic is totally white, looks leaner than normal. with the car running, if I remove the injector on 2 or 4,the car gains a noticable miss, like those are working properly, but 1 or 3 is a slight differance, so it's like those cylinders are doing kinda something, if I drive with 1or 3 disconnected, than the car is way less power, but either way the engine runs way rough and slow.
It's a 03 swap, and it sometimes starts right up, sometimes not, from cold I have to pat the gas for it to run, or it spudders and trys to die, then it will hold a high idle, but touching the throttle even a little causes a stall, it won't rev at all, EXCEPT once! I unplugged the map and it ran good. I shut it off and it won't run again well. I understand you should reset ecu, but It can't really properly work, since it won't start and run unless I pump the throttle. I tried changing the direction of maf, it didn't change anything, and all my hoses are firm, no leaks.
