kingbobdole
Everything posted by kingbobdole
  1. I have a set.... The left side was fine, but the right side had to be "stretched". I got the fender on, then broke it with the door. The top of the fender where it bends down should be like 90 degrees. Instead it was 120 degrees and pulled the fender in towards the car. Probably from having things placed on top. Also the top coat has the quality of a pickle. Sure are cheap tho.
  2. So I have two problem children. First is my daily driver a 79 fe 1600. Yesterday, when I shut if off, the charge light stayed on, and the fuel pump continued to run. If I unplug the alternator all of this stops. Also the wipers work with the car off as well, but it has always done that. Second car is my 78 brat. It has never charged. I put a set of brushes in the alternator, and a new voltage regulator, but no dice. Light works on the dash and I'm thinking it also just needs an alternator. Thoughts? Thanks!
  3. I can look on mine.... But what am I looking for?
  4. The seec-t was subarus emissions and fuel mileage engine. Subaru Exhaust Emissions Control Technology or some such thing. It basically had 9.3 compression vs the 8.5 or so of the others. It also featured an air suction valve to add air to the exhaust stream to help it catalyze. http://subaru-philosophy.com/post/36197498447/seec-t-has-been-proven-to-be-a-winner Most of my pics of its progress are here: http://i11.photobucket.com/albums/a190/kingbobdole/Fe/ This is what it looked like when I got it. Single owner, but he used the hell out of it.
  5. I have one. It's has the seec-t engine and higher compression than the other 70's cars. The five speed with double overdrive also has a lower final drive too, 3.7. I think it's neat. The 50 mpg is a highway under 80 thing. I usually get 40-45 around town.
  6. Dependent on rust I'm interested too... It's the right color.
  7. Actually my fe features double overdrive, highway speed I can get over 50. Around town I get 45mpg.
  8. That's kinda funny, I missed the user name. Sorry about your purchase spicy, but if you can install the cluster you can take it apart too. Not too hard, just take a peak inside and see whats going on. Maybe a stripped gear, but more likely it just fell apart and can be reassembled.
  9. I just bought one of those too, not too rust, but rahter stinky. I paid $200, but it felt like I was paying to haul his scrap away. Either way I cleaned mine up and it fired on the first try. Bled the brakes and gav it a light clean and it's still fresh. Go get it man, just be ready for some work.
  10. How much? I'm starting a halfway house for 70's subs it seems...
  11. Mines ghetto for the sake of being ghetto. Yes I drive it around like this....
  12. I've done this. My 86 GL-10 S/R PB 4WD turbo wagon is pimping an 91 Xt-6 awd DCCD box. Wiring is different, but I haven't got that hooked up. The shifter solenoids are "backwards" from where the hoses hang. So basically open center until the button is pressed. Also the rear transmission mounts are different as the 6's cradle is closer to the ej stuff. They mount totally differently to the case, BUT! The holes are there. I just used the wagons mounts on the Xt case. Everything else lined up and worked. Easy straight forward swap.
  13. I'm pretty damn good at these swaps and it still takes me more than a month to do it. I've got limited time tho.m first step is to build the harness and get it all installed. You can do that without down time to the car. Having the fuel pump, relays and engine wiring already in place will make the install much easier. Then the engine install is quick physically depending on experience. Then you get to make it up as you go to finish it off. If everything is right, you win. If not you get to scramble to fix it. Not ideal for a daily driver.
  14. I just got Zem's 84 GLF with a 97 ej22 swap. Car came with an EGR, ej didn't have it. I did have to mention the car is AWD tho. It did have a cat on it and it did fast pass. My 89 xt6 with the EZ30 also fast passed. The trick is to play a little dumb and make sure the car has the equipment it came with, like a cat. I like the weld county location at I-25 and exit 235. I've got a hs friend there and they are not usually busy. Pretty good crew there too..
  15. Owner: Zem Body: 1984 GLF Coupe Hardtop Engine: 97 Impreza OBS EJ22 Transmission: 97 Impreza OBS AWD 3.9 with VLSD 3.9 rear OBD2 compliant, scannable, super clean emissions. Custom trans mount, drive shaft, shift linkages and front axles.
  16. Check the powers and grounds to the ecu, at the ecu. How did you go about "removing the immobilizer"? Are you talking about the factory one? I have the ez30d, so I'm not too savvy on newer stuff, but as far as I know, the immoblizer does allow starter operation, but will not run the injection. Sounds like botched wiring more then bad ecu.
  17. This is a friend of mine. Great quality shirt. There are a few left.
