Everything posted by kingbobdole
Not my 86 GL wagon. It's carbed. Here's the story. The owner decided to take it apart to change the timing belt, and couldn't get it back together, not running anyway. So it came to me with the old "ran great before he messed with it". He kinda took the intake apart, so the vac lines may or may not be right, I checked them over quickly. He disassembled the interior to fix the heater controls for some reason. The spark plug wires were on wrong. Ok, heres the problem. It runs hellaticiosly rich. I put it on a 5 gas and was getting about 900ish HC at it's "best" setting. It also makes you dizzy trying to analize it. It also has a bit of a miss, idles rough. When it is driven the throttle has "dead spots" at 1/4 and 3/4 throttle... seems to sputter in those areas. What I have done: plugs, cap, rotor seafoam in the tank with some fresh gas seafoam down the throat of the beast(really helped the idle) some carb cleaner... in the carb new oil poorly and quickly checked and reconnected the vac lines. think thats about it... Ideas?
Rx is dead............ :(
kingbobdole replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
could be a internal turbo problem as well... -
But not in my car, or the ignition you are thinking of Working on my neighbor's wife's brother's 86 GL waaagon. The key is very hard to get in and out of the ignition and it is hard to get it to turn as well, like it's not lining up. Is there some secret quick fix(other then oil/silicone , tried that) that might help? Would a new key help at all, or is just new ignition time?
SPFI-vrs-CARB., 1.8, Is there a difference?
kingbobdole replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have an ex-carbby wagon.. I put SPFI on it and it runs a bit rich (or so the Etest says) Runs great otherwise, ShawnW was impressed with it's speed Vs a Baja.. and I've even got a lift with 29's... But like stated, you probably would lose a bit of power, but then again you can advance the snot out of the timing and still run regular since the compression is lower. -
Think I paid $200 for my running driving wagon... and it's not even really rusty.
I also have 17"s on my XT-6, with "5 lug swap":-p They are stock LGT wheels, 17x 7 or 7.5.. I do not recall which. I also run 205/40R17s and have not bent a rim and I've hit some pretty nasty holes. Biggest problem I see is that if my tire was too much taller it'd hit the suspension in the front. Also this tire is with in 1% of my stock 195/60R14(IIRC) size. Heres a pic.
1987 RX Project Guidance needed!
kingbobdole replied to Jellef's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EJ anything > EA anything. Even if you swap in a EJ22D N/A it will still be a huge improvement. -
Opinions on Austin, TX anyone?
kingbobdole replied to calazo's topic in Meet n' Greet. Your USMB Welcome Center
I've been there a few times... My sister lived by the river walk and it seemed like a nice place... -
to answer this.... it'd be a big wiring nightmare!
I'm gonna ask this... Why? The EA82T is much harder to cool then a EJ22... you stock rad should be just fine. I'm running my Rx's single row(stock form, but not stock one) and I have a SOHC EJ25. Runs cool.
fiberglass?? sheetmetal? no, Duct Tape!
kingbobdole replied to daeron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1... paint over it FTW:banana: -
a better angle of attack to knock the exhaust off maybe:lol:
EA81T oil cooler on XT-6
kingbobdole replied to kingbobdole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so.... ok then, I'm not getting ay cooling at all? I'm sure I'm getting flow though... the lines are getting pressure(using the pincher test) and the engine hasn't seized yet... guess it'll be fine for the next month or so till it's more properly routed. Now riddle me this, does it at all limit current flow to the turbo? I didn't think that a turbo could take the full 80 psi of engine oil pressure. -
I'm not sure I'll ever know, I'm just using it as a just in case and it also has a convenient "extra" port. -
So Shawn, or Mr Awesome as some know him by, got me a sweet EA81 Turbo oil cooler.. Today I made a rather annoying attempt to put it on my XT-6. It's not quite done, but all I need are hoses and a way to mount the cooler, probably those pushy zippy thingys. On with the show, Here's the "kit" stock First mod was to remove the old mounts and then I had to modify one of the oil lines. Then that fit ok So I made some room for the lines to pass through the duct on the PS of the radiator. And then I had to shorten the lines to the filter adapter and I got that mounted up pretty good... More pics tomorrow when I get it done.
While removing the intake on my 89 XT-6 to test fit some things I discovered this: The trans to firewall mount is not only bent to a 90 degree angle, but the mount itself has been snapped right off the tranny! I have no idea how or when this happened... unless it was that time I lost a bolt out of the tranny crossmember and the tranny fell a little bit... can't recall hitting the tranny on anything... :-/ I'll have to check my spares tomorrow and see if I have another.
Colorado Red Rocks meet July 29th
kingbobdole replied to kingbobdole's topic in Meet n' Greet. Your USMB Welcome Center
You guys should have said something... I had some sun screen in the car... I burn like toast. -
seems we snuck in a few pics http://www.awdpirates.net/phpBB2/viewtopic.php?t=24640 -
Paint question... Black hood?
kingbobdole replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yellow cars with black hoods are the coolest... -
+1... The SPFI shorty and the MPFI are the same compression... but as said the MPFI requires the 4 port heads, and related wiring... might as well just drop the entire engine in while you're at it... I also might point out that there is VERY little power gain.SPFI -> MPFI
I'm down when food's involved... Sonic? What else is good in Golden? -
No one cared when I brought my Rx last time... all kinda gave me the "Who parked their old accord here?" like looks. I'd be up for a BBq but bringing food would be tough... might have to get it on the way there, but IIRC there is a foods store pretty local. I'll be in the 6 BTW.
