subaruglkid
Everything posted by subaruglkid
  1. as soon as i get my license back i wouldnt mind driving to mount vernon every so often
  2. yea and fairly easy to swap. so lowering the engine does the require custom mounts or just moving them?
  3. well i was just curious because i figured it would obstruct the structural integrity of the hub making it weak. well there isnt many rims in the standard 4 lug 4x114 i believe so six lugs would be awesome
  4. oh ok ive also heard about some atv rims that could work. ive also got a set of toyota six lug rims and wondering if drilling the rim or the tire mount(cant think of the word right now)
  5. so when you say lower the front ill ;ike have to lower engine tranny and what not?
  6. so with out doin serious modifications could i run a 2 inch lift with 28 inch tires?
  7. hes got (had) nukes, would you want to argue?
  8. plus the subaru (depending on the lift) is much shorter than a lifted toyota thus a shorter center of gravity. widen that wheelbase and basically the more stable you get
  9. does randys or anyone carry some better axles?
  10. i have a weber on mine and once that second barrel opens its like vtec unless your at low rpms but yes the wbeer is awesome but for some reason i have a hood fitment issue with mine.
  11. well now that its been flexed both ways it prob wont stay where its supposed to unless your lucky. you might still be able to do the swirly method
  12. hehe ive got a machine shop at my disposal. i just need to understand what to do first. ive got the materials and the tools and pleeeennnnnty of time
  13. the only reason i wouldnt do this is because it sometimes has the tendencie to pop can and becomes flimsy and that noise from expanding and contracting can get really friggen annoying
  14. unfortunately the bad part about plungers is you have to push in to sunction cup it. if you can reach under there and from the outside of the circle push around and around in a spiral motion and should come out, thats what i do at least.:cool:
  15. clean it well my friend pretty much goes for anything with a crb tho. but use carb cleaner and everything. the better you understand how it works the better youll rebuild it. rock on:headbang:
  16. yes thatd be perfect cept mines a hatch. but yea ill put those 31s on and cut the fenders..
  17. at this point in time just lift it and put some meats under it
  18. i apologize i know your not all douchebags and how annoying new kids can be and i shall play the hurry up and wait game :-p so thank you.
  19. i have searched for an hour now and not found a thing so i was just lookin for a wuick answer if itll strip my diff or not before i slap em on
  20. i just bought my first subaru and id like to learn a lot more about doing stuff to it and im often in the arlington area and actually gonna go up to walker pretty soon i believe on the 29th
  21. so just cuz you say not tryin to be a douche means you can be a douche lol
  22. are 31 inch tires too much for my stock 1984 subaru gl running gear? i was also thinking of making my four lug into 6 lug any ideas?
  23. and personally i think it depends on what you are driving thats solid axle and what components it has installed.
  24. are 31 inch tires too big for my stock running gear?
