Miatadude
Everything posted by Miatadude
Old Guy from Montana
Miatadude replied to Bobinbigsky's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the group. Lots of great knowledge here. -
Back in the saddle
Miatadude replied to Responsible Jon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Keep up the good work. I will be starting on getting mine road worthy this Winter. -
I have an 82 in Georgia.
We Post Our Grievances Here
Miatadude replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lack of replacement body parts. Come on, its only 33 years old. -
82 Brat gas tank hose connections
Miatadude replied to Miatadude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you ihscout. Now I can connect everything properly. -
I am looking for a diagram that illustrates what hose goes where. When I bought my Brat, the fuel line was connected to the bottom of the tank. I found out this is the drain plug from a previous post. I need to know where I should hook up the fuel supply to. Is a factory shop manual available for an 82 Brat?
82 Brat gas tank fitting
Thanks for the help. Someone in the past used this as the source for fuel. I will look at it sometime today and figure what the correct location is. There are no threads on the present location. Is there a diagram that illustrates what fittings are for? -
I need help finding a part for my 82 Brat. I am looking for the fitting on the bottom of the tank that you attach the gas line to. There was one on there that I do not believe was stock. I attempted to seal it with a fuel resistant RTV but it started leaking within a few weeks. The one that is in there now is made of plastic. Any ideas?
1984 Brat update.. and a question
Miatadude replied to dustinsdad's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I put Escort seats in my 82. Very easy to do. -
There is nothing like a Subaru Brat...
Miatadude replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can't wait to get mine back on the road. My first was an 85 turbo I bought in 1995 in Phoenix. That Brat took me through a lot of the dessert. -
Hey guys. I have been off of the forum for a long time. Bought a new house and put the Brat in the basement. I am finally getting back to it. The problem I have is a leak at the "elbow" at the bottom of the tank where the fuel hose connects. I tried a fuel resistant sealer but that only lasted 2 weeks. Is there an actual replacement part? Any ideas would be greatly appreciated.
Thanx everyone. The last ones I purchased were at the park and swap out in Phoenix when I was stationed there. Now that I am back on the east coast, I was just wondering who to buy from.
Who makes a good dash mat for an 82 Brat? My dash is too far gone to restore. I want to cover the ugly thing with something.
82 Brat GL master cylinder.
Thank guys. I have had the Brat since last December, and got it on the road in January. I did bleed the entire system 3 times. It has never had a firm pedal since I have owned it. Will pick up a reman unit and go for it. -
I am pretty sure my master cylinder needs to be replaced. I adjusted the rear drums, but the pedal needs to be pumped 2-3 times to get decent pressure. Is a remanufactured ok? Would Advance Auto or Autozone be a good source? I did search, but did not find an answer.
I work for the Federal Government. When I train a new trainee, I get a 10% premium.
I have an 82 Brat. What does the relay under the drivers seat do. Mine is unplugged.
I recently bought an 82 Brat. The dash vent louvers are all shot. Where can I find replacements? I have not found any old subies in the junkyards around here.
I finally got the darn thing off. I hated destroying the thing, but I used a grinder to grind down the area where the roll pin was inserted. After getting down to the spline, I was able to drive out the old drive pin. It was a serated type that had some type of solid pin driven into it. It must have been made out of unobtanium because no drill bit would go through it. Now I need to get the brakes to work a little better.
I even tried heating it up with a propane torch and then drilling. I will look at small grinding bits for my dremel next. I bought autozone axles. I will redo my old ones for spares.........if I can ever get this one off of the Brat.
I have tried 2 cobolt drill bits with no sucess. How hard is it to change out the transaxle stub?
