palfer
About palfer
- Birthday 04/28/1972
Location
phoenix
Vehicles
97 impreza outback
palfer's Achievements
USMB is life! (4/11)
13
My 09' Legacy has 97K miles. I change the fluids at the appropriate intervals but recently the transmission has been downshifting inappropriately. Doesn't happen on every trip but occurs when I'm on a flat freeway driving 75-80mph. I'll be cruising along at about 3K rpm's and out of nowhere it will momentarily downshift. The rpm's jump to 4.5K and out of reaction I let off the gas pedal and it will immediately upshift back to 4th gear. The whole episode lasts about 3 seconds but its alarming as its completely unexpected based on how I'm driving. It doesn't trigger a check engine light but I pulled the codes anyway and I'm getting a C0045 and C0071
My 2009 (96K miles) automatic 4 EAT doesn't seem to what to make the shift from 3rd to 4th gear. Engine gets up to 4K rpm's and then it triggers the flashing AT Oil light, traction control, etc. I've checked the transmission fluid and the level is good. When I shut the car off and restart the flashing dash lights go away. Does this symptom ring a bell or any suggestions where to start troubleshooting? Thanks!
Hi My 97' Impreza just came up with a P1441(fuel tank pressure control-high input). I'm assuming that means the pressure is too high and the system can't relieve it. I connected the green connectors under the dash and was able to verify the purge control solenoid (under the intake manifold) and the vent control solenoid (above the charcoal canister) are both turning on/off. However the pressure control sensor (mounted to body on passenger side of hatchback behind the apron) is NOT giving any audible click or pulses. What I'm not sure of is if the pressure sensor is supposed to pulse when the green connector are joined. Any ideas? If not, does anyone know how to test if this is working? I also looked over my fuel filler neck and its got some rust. I don't see any pinholes but I'm thinking if there were that would trigger a P0440 for an evap lead which I am not getting at this time. Thanks!
Hi Everyone My 97' Impreza has the airbag light on. The cruise and the horn are still operational. I flashed the code old school by grounding the black connector under the dash and got back a 12. Airbag control module circuit open. Is this as straight forward as I need to replace the module under the center console? My only airbag experience has been changing the clock spring a few times with ones from a salvage yard. Thanks!
Remove both lower control arm bushings. They are ok, no play or movement Snapped a few pics of the stub shaft. The only part that looks like a possibility is the roll pin opening. The one side is pretty beat up. When the pin is installed the play in/out seems normal. There is also play side to side. Don’t know if that’s normal or if there should be no play at all side to side.
Well, I'm open to suggestions if you have any. I've basically replaced every on the passenger side associated with the driveline and I can't get rid of knock upon acceleration from a stop. If the vibration from the aftermarket axle was enough to cause the axle seal to fail perhaps it fouled up the shaft or worse the differential. Kind of at the end of my rope on this repair..
