Everything posted by BratRod
Replaced the module, and still nothing. Im getting 12v to the coil, and the - side is pulsing. New coil, new module, button, cap, wires, plugs, and disty has no play in shaft...
That's what I thought, I knew they looked different. Thanks GD
Ok, thanks
So I just received my new dash last week (thanks Rust) and according to the vin its from an 82gl wagon and the odometer readings check out so I believe it. My question is: will I have any problems with hooking the tach cluster up to my 85' brat gl? As far as connectors matching up. Any and all help is very much appreciated. T.J
yeah, the pickup coil. Some auto parts places have it listed as an ignition module
yepper, power to both sides.
Got power to coil & dash today, the problem was a SINGLE wire under the dash far before it hits the fuse box IN the harness. Still no spark, im going to order an ignition module.
Is Ned "cat-equipped"? Sounds like something that would cause those symptoms.
4 Little Subbies sitting in the trees
BratRod replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not all GL-10's are necessarly equiped turbos. And unless someone thought it'd be funny to put an EA82 in place of an 81, it should still be an EA81. Sorry Shawn, didn't mean to post what you just said again... Im on my phone -
Nice my Brat has a cherry bomb on it... A pretty old cherry bomb at that. Sets off every car alarm in the neighborhood :-p pretty cool man
My thoughts as well. I've had this problem on a 4Runner before
Great find, so jealous. Subscribed
Original brat roll bar fog lights??
BratRod replied to scooter0000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
eBay has them -
That's pretty cool. If that happened to my blade 400 I'd be replacing A LOT more than a control board :-p seems pretty durable
@Cougar That was my thought @scoobiedubie I've only ever seen one 88gl in my pic n pulls
If thats the case, I'll probably have to order one off here: Not many old Gen collectors that I know of down here
Nope still searching
I checked the black, blue and white. They are functioning as you describe; howerver, I also have black/red and black/yellow All fuses are getting good power on both sides
I'll go pick up a condenser tomorrow. On a side note if I run a jumper wire from the + side of the battery, to the + side of the coil I get dash lights. But very little spark
No burnt wires, and i checked for continuity.
all fuses are good, ingnition relay tests fine
Excellent! I guess I'll be doing this very soon, when it stops raining
Has anyone laid a nice coat of paint on these ever fading plastic interior pieces, I was thinking about it but wanted to see if someone has before
That's a J200 gladiator
1986 subaru brat ign key cylinder repair
BratRod replied to rayban1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I just did my cylinder a few months back and this is how I did it: Remove the plastic cover around steering column, steering wheel, combination switch, unbolt the steering column then remove the two spring actuators that attach to the bracket that pivots. As you will be able to see, there are 4 bolts on the lock cylinder (10 mm if I remember correctly) and not much clearance to get them out. I took them out with a regular combo wrench, and a lot of patience. After those are out, a little tappy and it should slide right off the shaft. I'll bet some other board members have done other things, but this has worked just fine for me! Hope this helps T.J
