Transmission is a 3 speed auto, P R D 2 1, with push button 4WD. Symptoms: Park is ok. P to R - wheels start forward for about a second, then stop as if locked. Neutral - wheels turn forwards. 1st - wheels turn forwards at relatively slow speed. 1st to 2nd - wheels turn forwards at higher speed. 2nd to D - shifts to yet higher speed. D to Neutral - wheels continue turning forwards even after braking to a stop. Neutral to R, (after braking wheels to a stop) - wheels remain stationary as if locked. Work to date: 1. Removed, cleaned, deburred, re-installed governer. No sign of apple coring on metal gear. 2. Removed, cleaned, re-installed valve body. 3. Installed new step-down vacuum diaphragm. Was leaking anyway and burning tranny fluid thru the manifold. 4. Removed, cleaned, re-installed brake band acuator. 5. Completely flushed old fluid out return line from radiator. I'm at a loss where to go next. Any ideas or insight would be greatly appreciated.
