7
Everything posted by NorthCoast
So pissed I missed it. I was hoping to have my clutch changed in time but it didn't happen. Maybe next year.
Steering shaft extension is 4". I just cut mine in half and welded in a 4" nipple. Not pretty but it works.
Don't think that will work for our cars since we have a cable driven speed sensor.
Lol...is it broken or just unplugged? Mine came undone when I did the lift. What a pain to plug back into the speedo.
I used to have a little chart taped up on the dash for the speed conversions. Good thing to have since now you are actually going faster than the speedo says you are.
4k. Great little winch even came with a remote.
New Project.. 2" now but 8" later....Lifted D/R Impreza (Turtle)
NorthCoast replied to one eye's topic in Members Rides
I've been looking for an Imp for awhile. I'll be watching this one. -
From the junk yard . Came off a Honda Passport.
Lock washers and nuts. No need to weld.
No need to lengthen the steering shaft for what he has planned.
Easy. Just get some spring compressors. $15 from Harbor Freight.
How many of you will bring off roaders to WCSS this year?
NorthCoast replied to ezapar's topic in Off Road
Which trails? I haven't been back home to PT in years. Thinking seriously about making the trip especially since there will be a mudpit. -
If you figure that out let me know. I can't read the CD I got with the instructions so mine are still in the bag. Anti-lift link up front.
No. I did the trimming for another set of tires I had.
I ran that way for 4 years and did tons of light/medium offroading and never had a problem with my axles. Adding the 1" OB body spacers actually helped my geometry.
4" The back is fine...not sure why I would need an alignment. You will need one since you are putting in all new struts. Mine are existing.
Before with OB struts and spacers... and After with 6" SJR lift.
8" strut spacers or are you extending the struts?
Here's a couple pics of her pinned down for freeway driving. Here's what I mean by pinned down. Now I need to fix the speedo and add the skid plate. No idea what happened to the speedometer. Maybe it pulled out when I raised the body?
I wish it was that simple. I checked them both then wrenched a wee bit too hard on the rocker cover bolts. Not once but twice. Luckily I had the spare engine sitting there and swapped the lifters since that was the quickest fix. I pulled the head off and realized I had the gasket on backwards. Definitely a face smacking moment. In my rush to get the engine done I checked most of the passages but not all and missed the oil pass through. The car is back together now and I'm loving the new engine. I did my first long range / high speed test this morning and drove the car to work. The power increase is delightful. It's fun to get a little chirp from the tires when transitioning from gravel to asphalt and not having to downshift on certain hills on my commute is nice.
Well now I'm a little ticked. Got the manifold out back on and started her up. She started right away and sounded good. One problem though, left head was pouring out oil. I'm confused. I torqued to the right specs. What else would cause this?
Send me a PM with your contact info when your post count hits 10. Split... The radiator hoses are too long. You should be fine with 16" and 18". Gloyale... Do you have any pics of the extended shift linkage?
Did you want just the body spacers or the strut spacers as well?
I did do the steering linkage already. I extended it 4 1/2". I haven't tested it out though. The brake lines were just unsecured from the struts and look like they'll be fine. For radiator hoses I got 18" and 20" flex hoses. Those will be going on tonight so I'll let you know if they're the right lengths. The one thing I haven't looked at yet is the shift linkage.
