About Señor Brat
- Birthday 01/01/1980
Location
The Great NW
Occupation
Scientist
Vehicles
1985 BRAT, 1982 BRAT
Señor Brat's Achievements
Advanced Member (3/11)
Anyone able to run a carfax on a 77?
Señor Brat replied to spicypeanut's topic in Historic Subaru Forum: 50's thru 70's
i was told carfax doesnt go back that far unfortunately -
Need electrical relays for '84 Brat
Señor Brat replied to dilly's topic in Historic Subaru Forum: 50's thru 70's
i had an issue with my starter wire on the back of the ignition. check there! -
Gen 1 DL vs DL BRAT differences?
Señor Brat replied to Señor Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bingo! Here is the broshure from 79 that details it: https://www.pinterest.com/pin/54746951693072762/ -
Hey all, I know this is the 80's+ section but the other forum doesnt seem as active, so here goes: I'm seeing a vin decoder site that lists both GL and DL brats from 1979. Source: http://vehicleidenti...subaru-car.html What, if any, are the differences between these models? Thanks all! SB
Hey all, I'm seeing a vin decoder site that lists both GL and DL brats from 1979. Source: http://vehicleidentificationnumber.com/vin-decoder/subaru-car.html What, if any, are the differences between these models? Thanks all! SB
It's inevitable...my weber questions. =\
Señor Brat replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look into the Quarter trick to block off the ASV's -
why is oil getting into carb from valve cover
Señor Brat replied to Tat2Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GD has a good diagram somewhere on here. I mimicked it and havnt had an issue since. -
re-do / check your pcv setup & hoses. thats likely the issue. -
Lift Kit install shop in WA?
So every lead I've found fell through.... still looking.... *Bump* -
what he said ^^^
Replacement Carburetor for EA81?
Señor Brat replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My vote, go with the Weber 32/36. You'll be happy you did -
83 DL Dome Light drama.
Señor Brat replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What they said ^^^^ only my passenger side switch works atm -
Help! EA82 Intake Manifold/Busted Bolts
Señor Brat replied to EasyDoesIt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I havnt run into this personally, but I do think I remember reading something posted by GeneralDisorder a while back explaining how to free broken manifold bolts... maybe try searching posts filtered by his UN? SB -
Aftermarket Accelerator cable problems?
Update: OEM unit was $26 and snapped into place in less than 2 minutes...... Wow, guess I'll be buying OEM parts from now on. Cant believe I wasted all that time filing down an inferior product. Still looking into how the ball&chain cruise control thing hooks to the pedal, but at least its drivable now
