About samneric
- Birthday 06/28/1972
Location
New Orleans
Occupation
Programmer
Vehicles
'98 OBW
samneric's Achievements
Subaru Nut (7/11)
12
So can I take the whole block to my machine shop for planing or do I have to take it apart into two halves? ..and with that information, can I assume that my new headgaskets are leaking at the bottom of the fire ring? Why isn't this part of all the threads I have read on doing this job?! I did a LOT of research on this before I started. Arghhh:banghead: I hope people learn from THIS particular HG job. I am going to use this car for rainy-day driving until I get some money saved up. I have a convertible that I can use in the meantime. Hopefully less use on the Subie will allow for more time before catastrophic repeat HG failure. Steve
Is this something I do myself with a machine shop straight edge? Something where I need to take the whole block to a machine shop? Where I need to split the block and take each half to a machine shop? My guess is no only because since driving it (two weeks now), I haven't been losing coolant - only having it displaced into the overflow bottle (which I am putting back every day). Ok - we need to define badly. My impression of badly is: needle at or above the two max lines on the gauge. When I drove it prior to repair, I was concious of overheating but couldn't do much when it did. So I always made sure the gauge stayed below the two max marks - it came close but didn't go into that max range. When it did raise I never let it stay raised for more than 1/2 a mile before stopping and let it cool down. The needle stayed on 3/4 for a few miles though during the several occasions it started to overheat. I hope this clarifies it a little. The headgaskets I took out were the black coating material kind which had obviously eroded over time. I got the car at about 215k miles and have no idea how it was driven prior. It may have been overheated before but the HG symptoms were not that bad when I first bought it - drove it 500 miles at least without overheating. What are the symptoms of excessive overheating in its life? My Subaru dealer mechanic only mentioned cylinder wall slippage, not warping of any kind - he said the heads are too small to warp. There is no excessive knocking so I assume the bearings are fairly decent. Steve
Hi all, I have decided to try and trouble shoot my recent Headgasket repair for the good of anyone else who wants to do it themselves. My leasons learned can be added to the knowledge already out there. So, in that vain, lets start with answers to questions that followed when asking the question "what now?" in another thread: I bought the Gasket and Seal kit for my year and model (98 Outback Wagon). The part number for this set is 10105AA401. This gasket set contained two Subaru head gaskets. Their part number is 11044AA610. These are multi-layered gaskets that look like the pictures I have seen elsewhere on here for the replacement HGs. I asked my local Subaru dealer mechanic his thoughts on the symptons and he mentioned the "cylinder sleeve walking" that you GG mentioned. He also said it is very rare. Symptoms after HG replace: Bubbles in overflow tank. Coolant being pushed out of rad. The overflow bottle doesn't fill up yet - the level raises about 4-5 inches. I have been using a turkey baster to put the water back in the rad after every trip of 20 miles. So my plan is to pull the heads off again and have their flatness tested with a machine shop straight edge. Then I will test the block surfaces with the straight edge. Then I will have the heads pressure tested this time I guess I will take it from there. previous threads on the HG replacement: After: http://www.ultimatesubaru.org/forum/showthread.php?t=133799 During: http://www.ultimatesubaru.org/forum/showthread.php?t=132115 Before: http://www.ultimatesubaru.org/forum/showthread.php?t=124451 Steve
So in my case where I used them and put it back together to find a bad seal, what do I do now? I was planning on pulling the heads off again, getting them pressure tested and checking their and the block's flatness with a machine shop straight edge. If the block is out - what then? Would have I have to split the block, pull the pistons out and have the block shaved? Would that affect the piston clearance? Could I do it without having the block split?! I definately want to know why my job failed but then need to know what to do about it..... Steve
I haven't tried removing the t-stat but I'm not sure what that will achieve? If I have bubbles and water is getting pushed out into the overflow bottle how can it be involved? My latest purchase was a turkey baster so I can periodically transfer the water BACK from the overflow bottle into the radiator Steve
