About bluegreene
- Birthday 09/06/1985
Location
colo
Occupation
self employed
Vehicles
I Love My Subaru
bluegreene's Achievements
Member (2/11)
0
Thanks for the help! I will check for that tomorrow. But I'm back to the question of why it would continuously seem like the cable is stretching out. Yea... chances are it fell onto the road as I was driving... Ok.. That does make plenty of sense.. that the hardware got tossed out of the way when it broke. there's a lot of old rubber hoses and boots that have corroded on this thing...
I've released the clutch cable and tried manually activating the clutch lever on the transaxle. It won't go into first or reverse and I was pushing on it pretty hard. The cable is routed the same as before but I did not zip tie it to where it was before. So if I release the hill holder cable and let the hill holder lever lay in place, I should tighten it 1/4" past that point? Nowhere in the reinstall of the clutch cable did I readjust the hill holder cable. I did not add the spring. It was hanging there (not attached to the clutch lever) after the cable and hardware broke. Also, the rubber seal on the clutch lever is broken and I'm afraid now that the hardware may have fallen into it. Could that be the reason why I cannot manually push the lever in enough to put it into gear?
Well... After replacing the cable, and every few weeks, I've had to readjust the cable because it starts to get hard to go into first and reverse. The nuts are not getting looser because I've noticed threads being added every time. Now, I'm out of room, the clutch pedal is hard to push down and today it started getting hard to go into first and reverse again...
90 legacy.... When I am moving slowly and turn hard to the right, I notice a clunking/clicking noise coming from the left side. Or at least I notice it more on the left because I'm driving. It doesn't always do it and does it far less when turning to the left. Seems like a strut thing because it sometimes makes a similar noise when going over bumps.
Just two days ago, my 1990 legacy started to make a whining noise which is directly connected to engine RPM. It sounds like it's coming from one of the idlers or one of the accessory pumps. I want to think/seems to be coming from the air conditioning pump. I was thinking about removing the air conditioning belt to see if it goes away. IF it is the air conditioner, I should be able to just remove the belt and not even worry about air conditioning right? (I don't ever use air conditioning anyway)
I've noticed though, that it will level out (it wont go under 1100) in a minute or so but if I drive off and stop at a stop light, it will still be high when warm (sometimes up to 1700). When it is fully warm ten minutes later or so is when it will truly level out. I guess I'd rather have it high than low for the cold season coming up... Still have those nasty snow tires. There is a crack in the IAC hose... Just going to replace that.
So now I don't know where the proper positioning of the cable is. Seeing how the hardware was missing to begin with, I'm not sure what It needs to look like. Just tested it and the clutch doesn't engage when all the way to the floor. Does this look somewhat correct? Pretty clueless here... You'll notice it's not fully seated in the space to the far right. Also, the rubber seal on the clutch bracket has cracked in half.
There's a C-clip holding the cable housing to the bracket before going through the firewall. You need to move the C-clip the same direction as the slot in the bracket (towards the fuse box). Thing is a mother F&$%er to get off. I ended up clamping a pair of needle nose vice grips on there and worked it off.
Got most of the cable off. Figured where the spring goes and now I just cant get the housing out from behind the pedal. I got the actual end piece connecting to the pedal itself off but not the place where the housing attaches to the floor board just before going to the firewall. I can't really tell if there's anything I need to remove.
This is what it looks like. I did not remove anything from the clutch assembly. Durania, you are absolutely right. Ordered one from the parts store to look at it. Then went to the dealership and the difference is astonishing. Every bit about the OEM one is bigger and stronger. Yikes, good thing I posted this thread. Thanks y'all. Oh and the parts store cable did not come with hardware. Out there looking at how to get the thing out... And where does this spring go???
So, I've discovered that my clutch cable in fact failed leading me to think my clutch had gone out. The cable has fallen into the rubber sealer and all the hardware attaching the cable to the clutch bracket is gone. Will clutch cable kits include everything I will want to replace? (There's a few different kits available at a local parts store. And it's hard to tell from the pictures) It's that 1990 legacy again. XD
