jrobe
jrobe's Achievements
Newbie (1/11)
0
Cool, thanks. Off the shelf is there only 1 thickness or do you have to tell them how thick? Not sure with a 2001 2.5 and 1996 single port heads?
What did you decide on the harness?
Jeff
I have had 0 issues on mine with the Cometic "hybrid" head gaskets. I had the heads decked and simply cleaned up the mating surface on the block. You have to follow the stock torque pattern for the 2.2 heads to the letter.
I was wondering if you had any head gasket advise for a 2001 2.5 block with 1996 2.2 heads. Not sure if I should modify the stock thin mls gasket or go with Cometics. If cometics how thick? I did have problems getting a set of Cometics to seal on a different application once. I also have heard if the blocks and heads are not machined that the Cometic have problems sealing.
Got any advise?
Thanks Jeff
