10
ivans imports last won the day on March 21 2014
ivans imports had the most liked content!
About ivans imports
- Birthday 11/15/1977
Location
lumby bc canada
Occupation
licenced mecanic
Vehicles
evryone i can get have 30
Recent Profile Visitors
ivans imports's Achievements
Subaru Master (10/11)
161
Found out this cool swap was able to use Ea 81 head studs in my 1.2 justy fit perfect and was way better to line up gasket and head. Was room for the 17 mm nuts and I think it will help prevent headgasket failure on turbo justy. Also at same time opened up chamber in head to drop ratio. Works good no more ping at 7 psi
I'd like to try to make a side by side buggy.
ivans imports replied to utcoyotehunter's topic in Off Road
Fit 35's onto the buggy gives me 17.5 inch's ground clearance and tires are 34 inch's apart -
One small note we remove the soiliniod and valves from awd and run direct line press to it give me locked awd replace all of it with one small tube. -
whoops on newer on old one is just above heater coolant valve
3 inch from blower motor
conti belt junk to hard of rubber oem or gates
- 49 replies
- 1
- turbo
- timing belt
(and 3 more)
Tagged with:
+1 4eat love that trans for offroader -
people always call my buggy a side by side drives me nuts[ it's a Subaru people ] anyway get one made want to see it I think the justy running gear's are the lightest -
Change the blower resistor is next to fan held in with 2 screws and has 4 wire plugin
