ivans imports
    10
Everything posted by ivans imports
  1. at what preshure do's the oil pump relif valve relive preshure at my buggy engine hitts 110 psi cold startup no spikes no bypassing and drops to 35 psi hot and i ran thiss engine in - 15 in the snow no problem has oil preshure on cranking before even starts mind you not a hydrolic lifter engines
  2. i'm just trying to keep the bottom ends from failing the light oil dosent stay at top side of piston that well here its 10-30 for winter and 15-40 or 10-40 for summer the coldest it gets here is -25 and thats very rare and most subarus round here leak like sivs so the thicker the oil the slower the leaks i run 15-40 in all my subaru engines always have no ill efects i dont trust 5-30 in any subaru engine just to light. but hey thats just my opinion with the rate of rod berring failures anything that may help is a good thing
  3. and a 2.2 impreza ran out of oil and koncking and a kocking outback and a blown tranny 92 legacy with 400000kms but hey she an't knocken cheers
  4. it all has to do with the expanison of the heads against the block as they heat up and cool down they expand and contract untill the gasket works loose they have had the same problem since the ea 71 headgasket have always been working loose on subaru moters since day one i think oringing whould still suffer from same efects cement the block mabee
  5. trying to upload pictures of the 77 81 and 80 brat
  6. hey how do I upload photo albums from photo bucket?
  7. guess I should have knocked on wood just got a 2009 STI in which might just have a cracked oil pick up knocking hard will keep you posted
  8. put a loyale five speed cable in it works better check the orings on the trans speedo output
  9. Just did that one its the low reverse clutch pack is at the very bottom of trans and needs to be torn down bummer check if it has manual low if not clutch pack is done
  10. go all out 3.3 svx moter sounds good or 2.2 turbo
  11. the cogged idler pully on water pump dont run it till changed thiss is very common problem
  12. subaru cats are very high quality and do not go bad often [non turbo ] have seen cars with 400000+ kms on origanal cats not pluged or any problems they get ruined from running lean or antifreeze contamination
  13. Thats why iv'e never seen it 05 and newer turbo cars dont see many of those cars looks like a valid problem though yikes !
  14. all subaru engines that are no hydroilic lifters get 15-40 oil and hydrolic ones get 10-30 have found that 5-30 is to light and will dammage bottom end subaru recomends 5-30 for gas millage pourposes not for longgevity. Have never seen a cracked pickup tube ever in over 500 ej engines have never heard of that ever till now dont think it whould matter anyway cracks whould be below oil level. Have however seen many oil pumps with loose screws on backing plate some had fallen right out thiss could cause oil preshure problems factory engines that had never been apart
  15. make a hybread axle use the loyale ends on the gl shaft will give you longer axle cups that dont limit out as easy had to do thiss with buggy it likes to shear axles i like that its a fuse and is easy to replace i carry two spare axles to evry race but is best part to break better than diff or drive shaft and it consistaly breaks there so i know where the problem is it was a bitt better when i softend up my posi in back now only breaks when doing dounuts in tight circles
  16. If they whould let me across border i'dd be there like dirty shirt oh well have fun boys
  17. any time it pushes out over flow bad headgasket and probly rad to change headgaskets and rad
  18. fastest way to ruin your car take it to dealer scary dealer mecanics are piad by the job and all that maters to them is how fast they can get the job done. eg when we asked the local dealer mecanic why he was orbital grinding heads instead of planeing them he replyed { WE JUST HAVE TO GET IT OFF WARANTY ] so who cares if it has problems later waranty will be off dealers and there policys are very shadey do not turst them i'm am personaly tierd of cleaning up dealers slopy shady work i wouldent even let them look at my car ever take it to GD or shawn or somone that cares about there qaulity control and reputation
  19. have cleaned cats before can be just washed out with hose strait water low preshure i whould not remove them cause the engine is tuned to have catts i have not seen any proof of power increase from removing catts on na cars and milage will go down cause o2s will not get hot enuff without catts
  20. thats it the red machine in pic the air is just to putt preshure on knurlling wheel
  21. the 2.5 1 seems to be the worst for thiss the 2.5 d will give some warning knock on startup or ticking lifters or knock when reved but the 2.5 1 just spins the berring and done could be just the age of cars but i have seen more knocking 2.5 1 s than 2.5 d s the 2.5 1s seem to die at way less kms than the 2.5 d most of theese had at least 250000 kms or better the 2.5 1 s all under 200000kms some as low as 120000kms spun berrings even not overheated. Run out of oil mabee or luged no oil changes not shure but they dont seem to hold up that well. The average loyale i see has over 300000-450000kms on them and most still have same engine mind you they tick and rattle and miss but still go i dont even like theese engines but at least they held up. Even the 1.2 seems to hold up better and its a known poor engine still go's 250000 kms min before problems i think subaru enginers droped the ball on the 2.5 1
  22. did they pull moter to do heads ? damage to trans imput shaft or tourque converter or timing belt tooth out \ starting in second
  23. i change them dayly i get the bellows from the dealer about 30 $ and a half hour to install only trick is to crank stering all the way to lock and use a small pick and burp the air out or will not hold shape right
  24. the ecu send injector pulse for #1 cly thrugh the idle moter if its stuck the injector will not fire properly if idle moter is dissconected will run on 3
