10
Everything posted by ivans imports
hey thats my buggy gota different engine now that was 4 years ago little meaner now
i put loyale front end parts in lenghten the strut bar and put arms in backwarads moves the front wheel forward 3 in and out 2 in with loyale front struts then i only need a 2 in block on strut and end up with 12 in of ground clearance with 235 75 15
its tortion bar with coil struts moved the tube from back to under middle and thiss made it 3 ft shorter its exacty the same length as width perfect square handels wicked 31 bogger paddles 2.5 single cam turbo with forged pistons 10 psi of boost 4 speed auto converted to 2 speed locked rear diff high stall with 4.44 gears she eats up the beach hit 110 on speedo in 2cd and never hitt rev limiter shes ready for dragrace season
Heater core hoses anywhere?
ivans imports replied to BlindSight's topic in Historic Subaru Forum: 50's thru 70's
Use the ones for a 2.2 b or forester oil cooler has nice 90 hoses that are very close i used those for my 1980 brat other day looks stock had to put a joiner right at firewall -
Looks like I have a bad headgasket...
ivans imports replied to shadman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I surface those heads take about 20 min and come out spanky -
Combustion is esacpeing from head bolts creaps through the head studs and comes out those bolt holes if you took head off you will find that head gasket was leaking into head stud a retourque of heads may help or headgasket
help
ivans imports replied to chadand1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
anuther comen problem on the end of the main shaft is a large 34 mm nut that holds the gears to the shaft it likes to come loose and alows the gears to move need to take off awd and tail shaft retiten the nut and should be fixed should be done before nut falls off and gets chewed up this is not a hard fix unless awd is damaged. Should check the end play of input shaft at same time -
The 2.2 i just did the timing belt was a bitt tight had to grind a tiny bitt off end of addjuster to get it in i used 2.2 b gaskets with phase 2 heads. In the offroad subies I do we mix and match alot but you must have an eye for deatails one differance thats overlooked and its toast. And i cant say thiss enuff CHANGE THE ROD BERRINGS thiss is any subaru moters weakest link and when they fail the whole moter fails.
I can hear the bad ones when they start cold if it is knocky for more than 1 second when it starts rod berrings are done the key is to time the oil light how long it takes to turn off when starting engine a new engine makes no sounds when starting and oil light is off before it starts. Any knocking on startup is a problem [not piston slap rod knocking ] till it makes oil preshure theese moters give lots of warning before they go you just have to talk to it.
88 gl automatic transmission problem
ivans imports replied to dmcluen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
chemicals dont fix problems worn is worn. Put your money into fixing the problem not throwing cemicals at it. -
Forward clutch pack fried or band soft part rebiuld is your next step. or deul range 5 speed
