10
Everything posted by ivans imports
Saved one 78 wagon from death dr
ivans imports replied to ivans imports's topic in Historic Subaru Forum: 50's thru 70's
I a'm not able to post pic for a long time on here have no way to do it sorry But was a way cool old girl 4 headlight fairly decent shape scored 4 tires and rims for it yesterday I will ask matt gl seadan to take some pics and post them. At any rate this car runs so good even I a'm blown away 8 years sitting and runs perfect I dident even put new gas in it -
Leone ea82 to ej15 engine swap
ivans imports replied to karuri's topic in Meet n' Greet. Your USMB Welcome Center
we use a five speed high low trans with adaptor plate and redrilled flywheel on the ej to get it to fit and is best to make ej harness stand alone then add it to loyale will need constant + and switched + and tach signal fan signal feul pump realy signal And lots of time. I have never seen a ej adapted to a ea auto trans do not think that will work right. And the ej 4eat is ecu controlled so can o worms -
ej 15 ej 1.6 never heard of those ????we have ej 2.2 ej 1.8 ej 2.5s -
have changed at least 12 filler spouts in last 6 months customers found cheaper ones on ebay / rock auto the 99 is different and must order the vent valve with it as they are rusted to I pay 260 $ for filler from dealer + 125 for valve. Not to cheap the rock auto one was about 175 including the valve. Takes me about 35 min to change and I just drill the screws out don't even try to turn them
Seems to be the worst on 99-03 foresters almost all the ones I see have a 420 code and have determined that the ecus were not callabrated correctly for are climate here in BC is just to mutch elevation changes for ecu to compensate for. The 420 code is to sensitive. I do see 420 on the odd outback / legacy but way more on foresters. And never on imprezas I blame poorly setup ecus Or the cars are stoned all the time !
Need a wiring diagram
ivans imports replied to Adam N.D.J.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
temp gauges never worked on those and do not think the analog dash plugs in -
Black wire with blue stripe off back of dash or ecu
- 5 replies
- LPG
- engine speed
(and 1 more)
Tagged with:
Finally scored one (Moss Green EA81 Wagon)
ivans imports replied to Greenley's topic in Members Rides
Wow I wish I could find one like that for my running gear from my 80 wagon -
A 2.2 is never done I fix this all the time takes some effort but can be fixed very common problem a new gear Key and crank pulley some locking compound and a peen hammer takes me about 1.5 hours to fix
- 29 replies
- legacy
- hesitation
(and 2 more)
Tagged with:
correct me if im wrong....
ivans imports replied to subi dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check frost plugs ! -
had two in one week that had a 1156 bulb in a 1157 hole If this has been done will short the taillight fuse and short brakelight fuse one car had no taillights other brake lights would not go off when lights were on and tails did not work both had 1156 bulb jammed in a 1157 hole and check taillight fuses both under dash and under hood
steering colum switch or has a 1156 bulb in a 1157 hole had two outbacks in the last week with 1156 single pin bulb in a 1157 duel pin socket this shorted the brake and tail lights across the circuit blowing the fuse and melting the tail socket. If you did this on front light would short the marker lights to the signal lights. But also have had a few with bad coulum switchs but mostly only will work one way or work when wiggled check signal / taillight fuses
Automatic Transmision HELP
ivans imports replied to taz ride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
govener gear is apple cored -
I am looking for more power down low below 1000 RPM
ivans imports replied to Scott in Bellingham's topic in Off Road
I a'm using a 92 turbo legacy 4 eat as it has shot peened main shaft and harder drums / baskets higher pump flow and a stronger rear tail output drum. I think the outback one will be just as tough but people still need those so not so easy to come by. But older 4eats easy to find and outback units even when bad diffs are good most of the time -
Is my gas tank THAT clogged?
ivans imports replied to BratRod's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on my lifted car is a gen two it had same problem so I put a trans cooler line with a 3/8 banjo bolt threaded right into the tank drain hole this increased the line from tank up from 5/16 to 3/8 then ran it to a 3/8 clear filter then to a VW high output cis pump then to my 2.5 turbo engine never runs out of fuel no matter how hard I push it. Then I used the stock feed line as a return line this worked realy good and 8 years later no problems -
EA71 Electronic Distributor
ivans imports replied to sjschlag's topic in Historic Subaru Forum: 50's thru 70's
you can use a ea81 diss as long as you also change the bracket
