10
Everything posted by ivans imports
Jackman center caps
ivans imports replied to Jonv23's topic in Historic Subaru Forum: 50's thru 70's
had same problem on 79 brat with jackmans i used the ones with bolt hole in middle and bolted them to axle fitt good i used a crome bumper bolt with slot cut in it to hold them on -
my avitar used to be one of those nice
go's for 1200$ new berrings rings surfaced block halfs and nurled pistons reasealed is very tight but just shot blocks i dont sell long blocks because to many different heads. I put theese 2.2 into 2.5 single cam cars because is way cheaper and heads will go strait onto a 2.2 makes for better relaibility.No idea what it cost to ship?
Spark but no start
ivans imports replied to MilesAway1980's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check for injector pulse should click and spray feul everytime engine is cranked most loose injector pulse not spark distruibutor must be grounded coil must be grounded coil bracket and ig mod must be grounded. Sounds like you smoked the feul pump realy is on top of coulom silver realy with red and bule wires next two brown ignition realy check that plug is not partialy pulled of the brown realy happens cause wires are short. -
Look for bubbles in over flow bottle when running hot = head gasket i put shop air into cly and look for bubbles in over flow one cly at time. Piston must be at top and have to hold the crank with bar i put 120 psi in cly and should hold with no leaks if air is geting into cooling syestem needs head gaskets. Almost evry weird cooling problem i get is headgasket i chek them first.
There is a bung on rear tail housing to check preshure put a gauge on it and c i did have one break the transfer line that moves fliud to rear of tranny is a 3/8 meatal line above the valve body on mine it just vibrated and broke but very rare. I doubt the basket sheard the splines theese are very tough and have only seen one sheard was on svx that was being neutral droped many times and still sorta worked even with sheard spline thiss makes a mess would see meatal in pan
i can dig some up do you whant a whole engine i have a very good one with ea82 carb on it runs very well i will get some pushrods together for you anyway
Fuel Tank Question 85 Brat
ivans imports replied to newgen85brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The only differance between tanks is the overall length i just move the rear xmember forward or back to accomadate tank -
Buckets are to loose set the shims 0.25 mm exhaust 0.20 intake you can set them without pulling the engine apart but you need a selection of shims find the loose one pull shim measure it see if you need to add or subtract by thicker on thiner shims.Must be at top dead center of the hole you are checking to measure clearance.
Rear axle DOJ problem.
ivans imports replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Love the messy subaru bench dosent hurt to look at a diagram in book shows the axle blown up so you can c all the parts -
Wow what alot of mess oly thing i can add is that subaru turns off the voltage to the soiliniod to engage awd not power it to turn on awd . when the soiliniod is off flows into awd cuircut when powerd it dumps preshure.When 2wd fuse is in it powers the soiliniod and dumps line preshure so no flow to awd. I run thiss tranny in dragster i tookout whole awd valve assembly and ran a soilid line to awd strait line preshure all the time my awd do's not slip at all. One more thing the less clearance the clutchpack has the sooner it comes on i set them 1-2 thow or less tighter is good but must still have clearance i custom set clutch packs to customers driving needs and location. some people need more awd than others.
Riddle me this Batman
ivans imports replied to ironworkerboomer's topic in Historic Subaru Forum: 50's thru 70's
not lifted stock hight i put some loyale rear coil shocks in to beefup the back can haul over 1000lbs in back dosent rub run a 195-65 15 on 6 in toyota 15 in rim
