10
Everything posted by ivans imports
Is my gas tank THAT clogged?
ivans imports replied to BratRod's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They have a sock in the tank that gos bad if you pull gauge sender you can look into tank and see whats up -
I have done many svx trans and headgaskets the trany is not to bad to r@r and is fairly easy to rebuild I like to use the 4.44 ratios with a impreza high stall converter then they haul
I am looking for more power down low below 1000 RPM
ivans imports replied to Scott in Bellingham's topic in Off Road
I put on 33s now up from the 31s that will test it more but gave me two inchs of clearance and raised the gear ratio a bitt -
Fuel trim is a o2 senser code o2 controls fuel trim. bank 1 is front bank two is rear
- 30 replies
- ej22
- Impreza Outback
(and 1 more)
Tagged with:
Put TBI on it works great !
Change front O2 senser the fuel pump is super easy right behind the rear seat back on PS side is a cover with 4 screws then you can see the fuel pump cover I putt a carter HP pump in mine for a wrx is 260 lpr vs 160 lpr stock one part # P74152HP made a big diference in my 98 outback sport
- 30 replies
- ej22
- Impreza Outback
(and 1 more)
Tagged with:
EMEREGENCY coolant leak I cant source
ivans imports replied to CarpeNoctem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what engine ? -
drilled hoke through head...!
ivans imports replied to justajester's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Howbout install a small plug and hilicoil below that aplug that's 1/4 inch should still leave you room below -
I putt my money on loose rear sus parts I test drive 40 subarus a week in snow and ice all behave differently depending on tires air preshures. And #1 how loose the rear suspention is the rear of a awd car is more prone to handling problems if any rear bushing / strut is loose at all. As far as the awd units go not near as many problems with that as there used to be I thought the newer cars they sorted it out. But the awd cars always had a push me pull me feel to them on slippery roads since day one standard cars were not as bad as the auto ones
floor it to start it?
ivans imports replied to TRAVIS75's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a snapon magnetic plug socket goes a long way -
can't find the right exhaust manifold gasket
ivans imports replied to odie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use that s--t on everything exhaust prevents those small leaks at the head -
Options for Rust Protection?
ivans imports replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Someone said fluid film coating helps best is to look at a members car that's rusty so you know all the spots to treat and protect and is worth it to pull some of the plastics to get to the hard to see spots
