10
Everything posted by ivans imports
Starts, runs rough, no power
ivans imports replied to frameexpert's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The end of the bimetallic spring on choke is broken off and choke is floating pull the 3 screws on choke spring cover and check Think you can use a generic choke spring to fix it -
Every single one I do has coolant in the oil you cant see it but its getting into oil the pcv pulls water out and leaves aditives / sugars in oil that can damage engine. The gasket is stainless so stop leaks will not stick to it just slip past it have been here many times. Have done so many Subaru headgaskets I paid for my 6000$ head surfacer in two years and it never rests. But I get very nice surfaces and have it setup just for Subaru heads with aluminum specific bitts. when the surfacer does its 1rst pass I can realy see the low spots on head The lower ds headbolt thru oil passage and front lower bolt on PS head are the worst spots always looks like oil filter is leaking but its not
- 3 replies
- Head Gasket
- 2.5L
(and 5 more)
Tagged with:
On the race car I removed the soiliniods and putt a air fitting on from valve stem now I sett preshure with gauge and done not addjustabble as easy but would work
- 28 replies
- 1
- air suspension
- gl-10
(and 6 more)
Tagged with:
I have been calling the heads/ gasket at 155000kms this is when the belt is due to be changed and timing belt job includes headgaskets / waterpump and timing gears and head surface have done 8 05 - 08 outbacks in a row is very commen what I can tell you is the Subaru coolant addative is not any good and makes a mess. just fix it right one time and your done
- 3 replies
- 1
- Head Gasket
- 2.5L
(and 5 more)
Tagged with:
Lowest a 4WD GL can go?
ivans imports replied to AWD J3wman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
4.44 gears is lowest LoL Just to mess with you -
#3 for me subarus feed my family and have for 15 years or more if wasent for subarus have no idea what I would be doing now. Subaru is not just a car brand its a way of life ! And after fixing mostly subarus for 15 years and having worked on everything else subarus are by far the best cars to work on. { Subaru feeds my family }
Water coming from exhaust pipe
ivans imports replied to Big G's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not drink it is the water sweet or not perty simple test -
Headlight suggestions?
ivans imports replied to RallyAlex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I run my power feed off the alt strait to my headlight realys then to lights no fuse hot as hell get 100 amps 14.5 volts on two 100 watt bulbs works spanky -
Anyone looked at how a jet is putt together or how there safty standards are I will take my chances driving a legacy around than taking a cheap flight. At least the subarus wings don't flap and flex down the road. But they are building cars super cheap nowdays its the only way they can be competitive with all the cheap crap hundyis and kias and Toyotas. And the money you spend makes 0 diff in quality ask the jag Guys who spend 4500$ changing one timing chain guide how mutch the saved spending more money of the get go. Rant rant rant lol
Taste it sweet or not ? -
Have exact car and love it put outback sus all way round 2 inch lift and twin ebrake levers and no mercy beat it all day every day never let off revlimiter I tell you one tough little car 11 outa 10
Prep tips for Running in Cold Weather
ivans imports replied to tdodge41's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My ea81 Tbi brat revs at 2500 for the 1rst 35 min of the day cold then very slowly comes down but never gives me any grief starting and don't have to touch gas peadal -
The rear 02 is very important it checks how mutch o2 is left in ex after the fisrt catt has done its job and ecu bases it fuel trim off that no rear 02 no fuel trim. Tps I never see problems with these sensers ever not on bad one yet BUT many bad wireing harness conectors and not fully pluged in conectors and broken engine wire harness that cause tps codes continuity check from main engine conector to plug on tps had a outback with broken harness between main conector and senser was a real pain to find and senser had been changed 3 times
- 30 replies
- ej22
- Impreza Outback
(and 1 more)
Tagged with:
try retorquing the heads have fixed two 2.2s this way even my own that was leaking badly got a turn or more on all headbolts and stoped pressuring rad
- 11 replies
- Head
- Head gasket
(and 4 more)
Tagged with:
