10
Everything posted by ivans imports
Lots lately 4 in a row all knocking I get the cranks turned down and replace the bad rod and away you go after endless hours of getting all the debries out of oil passages and cams tubes ect . I think this happens to these engines because coolant gets in oil thru bad headgaskets and end up with coolant additves / sugars in oil if not enuff oil changes wipes out berrings Also some years came with a 7mm oil pump was to small and could not keep up as it gets worn a bitt pump cant mantian preshure
how do i mimic a VSS?
ivans imports replied to lilpusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
perty nice reed switch for a old car -
Some old dodges used a 3way speedo spliter to make cruise work haven't seen one in a while speedo went to this unit and two cables came out one to cruise unit and one to spedo head think you could just plug a legacy speed senser into one side of something like that -
had a legacy with failed temp senser other day hard starting no idle cold and poor runability the fans also would not shut off have you tried a difernt maff
- 29 replies
- legacy
- hesitation
(and 2 more)
Tagged with:
NO SPARK
ivans imports replied to GAS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did you try washing out the boards on ecu blow it out and try again or is it burnt I may have ecu will look -
exhaust manifold bolts
ivans imports replied to pooreboy82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I drill the hole 1/4 inch deeper and tap it then use bolt from legacy head with stud bottomed out and locked in when it runs outa threads it sticks in the unthreaded part and will hold well -
So have been able to save two ej2.2 s now by doing a head retorque my 97 impreza 2.2 and a 90 legacy 2.2 when they get high kms the heads start to work loose the 90 legacy had 537000kms on it original motor anyway I got a turn and a half on each headbolt and the bubbles in rad stoped on both cars. I was surprised but it did fix them no bubbles since have putt on 5000kms on my impreza since coolant level has not moved. When I first got it ten minute drive all the coolant in overflow. Also check coolant strength may have frozeup
1997 Impreza Outback Sport Face Lift
ivans imports replied to impoutback 97's topic in Subaru Retrofitting
Try the deul E brake convertion took me minutes and what fun ! add a legacy posi and outback struts and spiked rally tires yeeehaaaaa ! outback sport ! -
Distributor Advance Question
ivans imports replied to joemlship's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timing belt But I think is diss off one tooth If you more it one tooth advance should sitt in middle of adjustment at 18-20 timing -
the loyale has speed senser built into speedo head in dash just hook it up belive is a two wire plug. Anyway since 83 is reed switch senser in spedo head -
Off one tooth or Tb off one tooth -
Is very hard to remove all air in rear rad setup try a rad cap fitting off upper heater hose so you can fill engine before startup you will have a air pocket traped between rad and lower rad hose conection and will most likely be very hard to fill. My rear rad cooling sestem hold 20 L of coolant the more coolant the more cooling medium at any rate make shure no air in engine or could damage it
4x4 and Blower problems... vacuum issue?
ivans imports replied to SLAVAGE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check vacume supply tp vacume storage tank were line comes off engine
