10
Everything posted by ivans imports
The headgasket denial runs deep no one wants to blame them BUT ME lol but is always the headgasket most times is because the rad failed or was overheated on a coolant fill at some point in its life
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
6 broken awds in five speeds in one month sounds like got a bad trans unit the rear berrings go and tears the awd apart check for meatal in the oil or any tiny bitts. the ujionts are replacabble. pn 1-0430 neapco ujiont. Anyway of the 6 i dd 5 were 01-04 outbacks all bad awd seems more commen on outbacks as they are heavyer cars. Also i put 4.5 L of oil in them keeps the awd in oil all the time and makes trans less likly to fail. Have determined that they die from long downhills all the oil ends up in front of trans and backend runs dry overheating the awd unit untill it pops the snapring and eats itself
oil preshure check min 10 psi hot at idle if higher engine is ok if lower do bottom end List headgasket x2 seporater plate x1 front crank seal x1 front cam seals x4 must be brown subaru ones valve cover gasket set intake gaskets ex gaskets plugs waterpump/ thremostat subau stat only coged idler or timing belt kitt timing belt. MUST surface heads check block for damage and burning on lower part of fire ring and make shure Cam buckets go back in exact holes they came out of and that they have adaquite clearance to tight will cause missfires
Same as loyale check the ground were coil bolts down bracket MUST be grounded to get coil/ efi to work add a extra ground wire from coil braket to - battery terminal also the xt6 uses a computer in trunk and is very prone to voltage drop as the wire harness is so long check + side fuse box and conections and voltage at rear of car is same at front of car
Anybody run into this?
ivans imports replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check cold air dr addjustment I remove heater core remove bottom tank rod it out and resoilder end tank back on then good heat -
had one that the two hoses on the rollover vent on filler tude were reversed made for very slow fill swaped them back and problem gone
- 3 replies
- 1
- Codes p301
- p302
(and 3 more)
Tagged with:
One after the other every day all day the local parts supplyers canty get ej2.5 headgaskets fast enuff but if you want to 100% confirm it I use a comp tester hose in cly with shop air blow gun attached at tdc on the ?abble cly holding crank locked with bar putt shop air to cly min 120 psi and watch for bubbles in rad any bubbles hg this test never lies. And is 100% acurate
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
EA82 Oil Pan Leaks
ivans imports replied to stratman977's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there should be holes in the xmember to put long #3 philips thru to do up bolts or a ten mm swivel socket on end of 1/4 inch ex works to -
EA82 Oil Pan Leaks
Ditch gasket and just use ultra grey as gasket like the new motors do the cork pan gasket was a pos and never sealed that well -
Yup tell me about it when they bring you ej2.0 head studs for there ej2.2 motor arrgggg !
- 9 replies
- Head bolts
- dumb mistake
(and 3 more)
Tagged with:
Headgaskets always the headgaskets were heads planed ? I a'm constantly redooing headgasket jobs that people/ shops did poorly or got wrong of the 20 ej2.5ds i did this year 15 had had heads done less than 50000kms previosly they are so picky on the surfaces is very hard to get a good seal. This is why i bought my own head surfacer so i can get the best surface posibble when doing heads. And 90 % have burns on lower fire ring surface more than 2 thow deep
- 25 replies
- 1
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
And then there's this thing...
ivans imports replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would use a egr soiliniod from a outback dose same job and way easyer to find and dosent fail as mutch quwick fix whats with all the tickets ? I been a licenced tech for ten years and have been working on subarus for 18 years. -
Down hill yes start up mabee slightly for a few seconds but lots of oil and not stoping smoking rings. Ex get alot of damaged valve engines 3 or more bent valves even runing on 2-3 cly valves bent guides seals damged no smoke just pop pop pop out the ex yes a bad valve seal or guide / valve could cause oil burning but not alot just minor oil burning. When they sitt over night if rings are bad at all the oil slips past the lower part of oil ring and gets on top of piston so when you start in morning puff o smoke.
