ivans imports
    10
Everything posted by ivans imports
  1. As long as they use steel gaskets they will never fix the problem If they whent back to grafite gaskets problems would be gone but steel gasket between to aluminum surfaces will never last
  2. have had a few of that year doing that some came with a 7mm oil pump and I think it was to small to mantian enuff preshure so bottom end starves for oil
  3. even with no valve seal would be minor smoke the ea81s proved this as they ran no ex valve seal valves dont make it burn oil rings do
  4. My 81 brat has full deuls two glasspacks xover and two bike mufflers one on each side blows rings out both side when cold and loud but not to loud did not make any power diff but sounds cool
  5. The piston oil ring oil feed hole should have been cleaned out and new rings this is your problem in those years they use very thin oil rings and they plugup badly try a cupple oil changes in a row may fix it or rering it. Oil burning was a big problem on those years oil rings just to small
  6. I found putting a clear feul fillter under the hood helped could see whats coming up to carb is good diagnostic tool
  7. We just couldent get standard trans to hold up to high hp no matter what. Keeping in mind my auto is not compleatly stock we put outback forward clutchpack and drum into the early 4eat gives me two wide clutchs instead of 3 thin clutchs and tougher basket other than that stock. I also only use 1rst / 2nd gears have no need for rest as it will do 110 kms in 2nd. Sorry a'm not trying to tell you guys what to do just what worked for me. A'm going on to almost 18 years of bagen subarus in the bush and many many hours of subaru offroad in many difernt setup subarus.
  8. Make cardboard drawings of front / rear covers and mark bolt holes on it so yo can keep all bolts in order of were they go this saved me hours. And took minutes had 6 or 8 templates this is the best way i can think of as many of the bolts were differnt lengths
  9. 6 07-09 outbacks with blown hg one 07 outback only had 120000kms and leaking oil all over exhuast others around 135000-175000kms I have seen no proff of any kind they that they fixed the hg problem worse if anything. Even the old 2.5d s at least went 200000kms to 300000kms before they blew
  10. I take a bolt / nut with two insulating washers non conductive and bolt thru the meatal / plastic so is a boltup conection can use mutch larger wires and no tiny pins to go bad have had to do this on a few now and a dozen other cars to somtimes is easyer to just go around the problem
  11. I installed a rebiuld engine yesterday took 10 seconds for oil light to go out I do not crank them at all just fire it dont want to push all are assembly lube out cranking with no oil preshure is bad thing just fire it remember pump is trying to pull oil up hill and you dont make mutch rpms cranking
  12. it thinks its leaking gas so is pulling vacume on tank the new cars moniter gastank vacume at all time even not running so probly normal
  13. oh no we run this thing for tank after tank of gas on my freinds unlimited beach 100kms of beach front hills jumps rock piles sand holes mud pitts ect I putt it thru hell trying to break it before race season hours and hours of abuse 3 drivers 3day 3 times a year in the end we broke 4 rear axles and colasped one front strut trans never got hot. Even in two ft of snow pulling very hard under boost still never got hot warm but not hot
  14. Have you checked the main engine harnes conectors are pluged in all the way and no bent pins
  15. Standard ? have been changing speed sensers like crazy they seize up and stop working 2 in one week 6 in a month all intermitant speedo or non working
  16. I did one two days ago that belt was striped and when we putt new belt on. One tooth from old belt found its way between new belt and crank gear and jumped 4 teeth had to reset belt ran for about 10 seconds then dead stop
  17. Chage hubs splines are worn to badly also watch out for axles with older car ends on them have had rebiuld axles with 70s outer ends slight diff in spline length and will never titen right. Also make shure 200ft lbs or better on that nut
  18. I did a piston on one was crazy hard 285 bolts one piston pin In center cly [ what a pain ] anyway timing covers and componets was crazy amount of parts. Had to make cradboad templates to keep bolts organized and coverd the whole floor of my shop with peices before i got to cly head . Took me about 15-20 hours with motor out. One other note have 3 of thoose engines two had oil cooler to block ishues were coolat was getting into oil somthing to do with orings on oil cooler halfs. The one engine i have has 380000kms on it headgaskets were fine
  19. I biult that engine this week go's for 2500 $ full rebiuld and sell them as fast as i can make them I do have cranks and blocks ect if need peices
