10
Everything posted by ivans imports
Stripped exhaust studs
ivans imports replied to Markus56's topic in Old Gen.: 80's GL/DL/XT/Loyales...
he said was not enuff meat to get a 10/1.25 hili coil in so next size up is a standard one 11/1.25 is real pain size to work with -
I need a part number for my Loyale FWD
ivans imports replied to Sandrion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
were it threads on to rack not at kunkle -
if you are very carefull can drill about a 1/8 deeper to get threads below the damaged threads but i whould jump up to a 7/16 standard thread hili coil -
Transmission BRAT 1989
ivans imports replied to STiAMV's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pics -
Ah the death crys of the dying ea82 let it rest in peices lol
no alinment needed unless you messed with tie rods -
Testing Idle Air Control Valve Solenoid
ivans imports replied to yblocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can hear it in action makes a huming noise in the intake pipe whooooooooooo louder it is the better its working and if working should have high idle cold about 1500-2000 cold -
Spider Manifold EA82T: timing marks
ivans imports replied to wagonist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have a full set of serp pullys for ea82 saved from 87 xt turbo -
I use a memery saver is only for 05 and up cars with drive by wire to save idle settings and ecu memery on pre 05 cars no piont. But very critical that 1 the key is off all the time two nothing else at all is on and 3 negative last to be disconected and last to be reconected. If you putt + termanal on after - termanal can damage ecu or other curcits had a 07 outback that customer just riuned ecu by changing his own battery hooked up + last and small spark and check engine light and no idle. My memery saver is only 10 amp so any more drw than that will pop fuse
1989 SPFI EA82 Code 55
ivans imports replied to mike300z's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Use a outback one 90 % more reliabble and easy to find will have to modify wire harness but a good fix -
have a rebiult ea82 bottom end been sitting on shelf for 8 years from 85 mpi non turbo car new rings and rod berrings if yours is damaged
Throttle body hard stop must be set right or dosent make idle contact in tps and will not let ecu gointo idle mode -
seals skf #20447 # 20445 berrings 6207j x4 2 per side seals 2 per side -
Why do you guys love the EJ22? Confused...
ivans imports replied to nobangmycar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
any 94 and older 2.2 head on 2.5 is non interferance engine have made a few now must use thick headgasket from 2.5d but works fine and have used 2.2 heads on 2.51s and 2.53s. The ej 1.8 is probly the toughest ej engine and the ea81 is toughest ea engine but has weak pistons ej not as weak pistons -
new to subaru engines and have a question
ivans imports replied to CODYZOOMZOOM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the carbed ones rev higher and make more power less mpg -
Fix the cv by changing the axle outputs on front diff
79 GL Wagon front end crunch-need some parts
ivans imports replied to def's topic in Historic Subaru Forum: 50's thru 70's
is just sitting here if you cant find one
